Kodak EasyShare C613 Digital Camera Logo
Posted on Aug 23, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodak C140 Photographs are blurry with lines. Video okay.
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Aug 23, 2009
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
213930
Points
1924
This sounds like a ccd problem, but may not be.
No matter, the camera needs some kind of repair.
Get in touch with Kodak, they may fix the camera for free if the ccd is a problem or damaged from the factory.
There may be other problems such as a loose cable in the camera itself.
The video is moving, but probably has the same event lines, but may be hard to see because it is a moving picture.
To test it to see what the menus are like, turn on the camera and run the menus. If no lines are in the menu screens, then the ccd is more than likely the problem.
Also, you ,may want to try this: Reset the complete menu back to the factory settings, most cameras have this setting. What tis may do is to reset all settings and may solve the problem...if not at least we tried.
Kodak c140 photos shows horizontal lines
I think, it's a CCD Error. That means a complete Line fails.
What is the memory capacity in Kodak EasyShare C140 Digital Camera?
a quick and very simple Google search mentions that 32GB will work and class 4 or higher...... but why you'd want to put that much memory (or more) into a battery eater i don't know..... forgive my sarcasm but i was curious of how hard you actually tried looking, and i deduce you didn't try at all!!!
Maximum memory capacity in Kodak EasyShare C140
The C140 works with SD and SDHC cards, up to 32GB in size. By swapping memory cards, you have essentially unlimited memory capacity.
You may use any brand SD/SDHC cards, though personally I would stick with the major brands.
2helpful
Need cd for kodak easyshare c140
You may download Kodak software and more from here.
Bear in mind that you don't need Kodak software in order to use your Kodak camera.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Coloured scratches in the images
The lens maybe damaged due to high radiation. try repairing it by going to the shop were you bought it. maybe they will knoe the problem.
I have a easyshare camera c140 but no manuel for it. Are they available some how?
User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/19119/kw/c140
Extended User Guide:
http://support.en.kodak.com/app/answers/detail/a_id/19116/kw/c140
1helpful
I need to know if the kodak easyshare c140 has aperture mode
No. One problem with many point&shoot cameras is that they only let you point and shoot, giving you little to no control over the other aspects of photography.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
