Dec 20, 2011 - aviator's Avatar ... When the high idle is no longer needed the piston retracts and the throttle ... Sometimes the piston gets gunky and slow to react... clean the ... you are already idling higher then normal the idle up will only be worse... for ... it takes to kick down when I first start it up, high idle is at 2200 RPM it ...Missing: lincoln
Oct 27, 2007 - ... King Ranch · Lightning · Lincoln Blackwood & Mark LT · SuperCrew · SVT ... my 2000 when its been sitting goes up close to 2k then drops down in seconds. ... so what your saying is when it's cold outside I can expect it to start andidle at 2200 rpm. sounds pretty off to me. ... Vehicle: 2004 Ford F150 5.4L.
4.6l Intermittent High Idle. Why?
Jul 12, 2005 Dual remote oil filters????
Jun 29, 2001 More results from www.f150online.com
All the above is normal , except 2000rpm is a little high at idle . can be adjusted down to 1500rpm. the computer adjusts the engine speed . in drive the transmission loads up the engine idle drops to 1000rpm . in park engine unloaded rpm increase all normal.
the normal rpm is from 700 to 800. after 900 is too high since the car is runing too high at all times there is a vacum leak a hose or intake gasquet but check the idle valve may be stuk open
I bought my 2004 aveo 49 miles. I've had several issues with the car. But recently I been experiencung high idle at start up and clutching. I change IAC. Plugs and wireds. Nothing worked. Today the high idle became constant. It was a metal bubble flex tube near the IAC unit that goes to the exhaust stuff down behind the motor. It apparently was cracked cause today it broke causing the constant high idle sound like a vacumn. We blocked it off with a stick to get the idle back down to 900 rpm instead of 3-4000 rpm took we can get to auto zone for high temp hose per Chevy dealer. I hope this helps someone cause it was fustrating and costly.
normal for an engine to start at elevated rpm and then die back as it takes a few seconds for the ECM doing it's sensor checks and idle back to the correct idle speed
check the idle rpm with an external rpm counter as most in dash units are inaccurate at rpm lower than 1000
as for the temperature
If you have a climate control module, it uses a mixture of heater and ac to maintain the temperature that you have set
so check it for operation
