SOURCE: How do i disconnect the oil pump/injection system, Fuel oil ratio
Hi Dan,
Why do you want to disconnect the vital oil supply? If you are experiencing too much blue smoke or plugs oiling you can adjust the amount of oil fed to the engine via the secondary oil pump cable,the one that splits off from the throttle to the carb.
If you disconnect the cable it also stops the oil pump sending oil to inlet, winding out adjuster increases oil screwing in reduces.
As for ratio? trial and error as No knowledge/specification is available for Oil injected engines, poss 25:1 to start but don't blame me if you seize?
Quality synthetic oil is always a must, did you know you can also purchase smokeless two stroke oil?
Good Luck!
Paul 'W'
Please remember the Fixya button if my efforts are respected?
SOURCE: What is the gas and oil mixture ratio?
Hi, McCulloch chain saws have different mixtures depending on whether you use their brand or generic and is also dependent on the model. The three mixes are 32:1, 40:1 or 50:1. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little. If you see any coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
SOURCE: ignition point gap and spark plug gap inboard outboard omc
.019 for the points and .035 for the plugs
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
Lou
