How do I take off or get to the control panel on a Maytag washing machine model # LBR4132JQ?
My washer won't stop filling...the appliance repair guy said to take off the control panel & next to the ''size selector'' is a tube...he said see if that is clogged, or loose, or disconnected, etc...the only problem is I don't know how to get to the control panel. Can someone please help?
First, does the machine stop filling if you pull the plug? If not, he is wrong and you need the fill valve. The piece the hoses go into. If it does stop when plug pulled then he is likely correct.
Pull machine away from the wall. Disconnect power. The control panel has two plastic end caps. The rear edge of each end cap will show a hole which has a partially covered Phillips head screw in it. Put a screwdriver in and remove the screw in each end cap.
Move to the front of the washer. Grasp each end cap and pull straight toward you about 1/4 " to 1/2 " then lift. The control panel should disengage from the top of the machine. The top of the control panel stays attached to the back plate of the washer. Rotate the front of the control up. This will expose all parts in the control panel.
Look for a 1/4" clear hose coming from inside the machine to one of the switches. This small hose can become detached from the switch and not send the "full" signal to shut the water off. It may also develop a small air leak which prevents the signal. If the hose is detached...reattaching and adding a hose clamp will prevent future detachment. if not detached, the pressure (level) switch itself is likely the problem.
Reverse the above process to reattach the control panel. If the machine is full spin to empty before testing your repair to remove water from tube. Good Luck.
Testimonial: "VERY fast reply...thank you so much for your help!"
Thank you so much! It was the tiny hose! Yay...what an easy fix. We are a family of 8...so we REALLY needed our washer to be in working order! :)
