I pulled the cord to start my weed eater and it wouldn't retract. I went to the manual and followed the instruction on how to restring the starter rope. After reassembly, the cord is hard to pull and still will not retract. Any help would be greatly appreciated.
P.S. I had the same problem with another model 2 years ago.
The spring is either broken or the catch on the end of it isn't seated, this is a coil spring inside the hub, probaly has to be rewound to gain the tension back
Testimonial: "thanks for the feedback. i was thought it was the spring. just can't figure out how to keep the spring in place while putting everything back together"
This a common problem but you can fix it with a new spring I think you will find that most of the more inexpensive trimmers are easier to buy a new one than to put alot of time and money into the old one
Testimonial: "unfortunately i'm starting to think that you are correct. i just hate to spend $$ if i don't have to."
remove pull cover and check spool if sitting flush ,not broken chipped or cracked ,rope not frayed or jammed,turn spool to retract the rope if no resistance spring either broke or popped out of retainer and further disassembly required caution when doing so spring can still have tension the following link shows different type of pull start problems and repairs Replace Pull Start Cord Yahoo Video Search Results
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
