Bosch Nexxt 500 Plus WFMC5301UC Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rid of Mildew Smell?
The inside smell mildewish and i want to know how to get rid of the smell
Karl Wright
Level 3:
President:
  • Master 1,653 Answers
  • Posted on Sep 12, 2009
Karl Wright
Master
Level 3:
President:
Answers
1653
Questions
Helped
758907
Points
4902
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
394
Points
After each wash is complete and machine is done for the day leave detergent door open. Allows to vent & dry out insides to eliminate mildew odour.
KJ
Anonymous
Level 3:
Brigadier General:
  • Master 4,088 Answers
  • Posted on Aug 22, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
4088
Questions
0
Helped
1512390
Points
12435
Run a cycle, without clothes, with a small cup of baking soda, hot water and normal detergent.
Smell of mildew in washer
They make products to eliminate this mildew, check at the store.
I just want an owners manual for my LG WM2010CW. We bought our house with this great washer, plus I have a mildew smell I can't get rid of
Sorry to say but the mildew odor is from excess use of detergent. The only way to truly get rid of it is to have the tub assembly torn down completely and cleaned out. Also replace the front door seal gasket to truly get rid of everything.
For temporary, you can use a chemical treatment called Whirlout or Affresh to mask out the odor but it won't totally get rid of it.
Good luck.
The inside of my maytag epic front loader washing machine smells like mildew. how do i get rid of the smell? its making the clothing smell bad too.
Buy some Affresh cleaner. You can find this at Home Depot. It should clean gookus from front boot. Also, take a dry rag and `clean the boot area of mold and mildew. I know some of my customers just leave the door open overnight to let it air our.
2answers
What can ido to get rid of musty smell
Here is a tip that I wrote about that...
Stop Washing Machine Smell, Mold, and Mildew
http://www.fixya.com/support/r3993813-stop_washing_machine_smell_mold_mildew
heatman101
3answers
How do I get rid of mildew smell in Siemens UltraSense front-load
Siemens
WFXD8400UC Front Load Washer
This video will show you how to change the door seal gasket on your washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Strong mildew smell in washer is making cloths & towels smell bad, how do you get rid of the problem?
if you look inside washer there is a rubber rim on the inside around the openning. Look inside and you will find where the stink is coming from. Keep door open when not in use and wipe inside of rubber trim to keep the mildew out.
I use tilex sometimes and do a rinse spin.
My daughter left clothes in the dryer and they werent dry now my dryer smells soured. how do i get rid of the smell?
Try tossing a tad of dry baking soda in with the clothes in may take a time or two but it would be better than tossing the dryer. If it smells like mildew also maybe try placing some charcoal inside withe door shut, charcoal draws mildew.
What is the sanitation cycle for on Model
Typically "sanitation" cycles require hot water....then they add more heat to the washer during the cycle. It is not 212 degrees, but it is very hot and does kill most germs.
The mildew smell is normally caused by water remaining in the system lines - because the water drain pipe is too high and keeps too much water inside after the system pumps the interior pan. Suggest that you just pour in some bleach after the last load...that should kill all mildew. Please do not overdo it. Only about 1/8th to 1/4 cup is needed to keep the mildew smell under control
Mildew smell
Try doing just a hot bleach water "load".  Also check underneath and around the machine to make sure it's not leaking.  If it did or is and you can see the mildew just spray it with bleach.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
