Efficient Networks Siemens 5930 Router Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Configure router to different supplier
How do i change from orange to aol using a se 572 siemens supplied and configured to orange
Anonymous
Level 2:
  • Expert 41 Answers
  • Posted on Aug 23, 2009
Anonymous
Expert
Level 2:
Answers
41
Questions
0
Helped
9960
Points
140
Hold the reset button at the back of the router for a couple of seconds, connect your pc and run the installation. During the installation process, it will ask for the ip address, input the new ip address of your new provider.
1helpful
I am trying to connect a repeater to my orange router and it asks for a pin no which i cannot find any body know where it is trying to get orange to reply is a dead loss
your Siemens PIN is the default written on the manual.
The orange router pin is appearing instead in the configuration page of the router (at times you have a sticker in the bottom of the router or on the back of it)
Regards
1helpful
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
How do i reset my siemens gigaset se 572 router
I have only been able to find info for the 555, not the 572. Bit it MAY apply.
See if there is a reset button in the back of the unit. Press and release to reset the router.
Press and hold for 5 seconds and it will reset with everything for the factory defaults.
As I said, this actually pertains to the 555, but it may also work for the 572.
Im trying to connect a siemens gigaset se 572 router to my sky broadband
do you have a connection in your modem?
cause if you do you need to set up the router in bridge with it means it has to be on DHCP (the configuration)
2answers
I cannot connect wirelessly to a siemens gigaset se 572 router although I can connect with a hard wire. I am using a Netgear WG111T wireless adapter. When I try to repair the connection I am told that the...
Check the type of encryption the 572 is set for, I've found a few cases where it needs to be WPA and not WEP. As a temporary measure, you could switch off wireless security.
Lastly, check your not getting a channel conflict, if a neighbour has a wireless access point with the same channel, you may get problems, which will require logging onto the 572 and changing the wireless channel
I cant connext my daughters Ipod Touch to the
I think there's a connectivity problem with your router please try to change it ...it will help a lot and buy a different company's router this time.
Thanks :) Please rate.
2answers
How configure Siemens Speedstream 2614 Router for Dynamic DNS
Siemens Speedstream info is on Efficient Networks web site.
Here is the complete manual (not the install one). It has all the setup functions :
http://www.theusermanualsite.com/mdownloads/7868b34e-d8db-c454-5914-3161ac8114c3.pdf
Here is a link with a host of info for your router:
http://www.dslreports.com/faq/10184
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
AOL DSL Plus
AOL DSL+ now uses PPPoE for authentication bypassing the client software. To set up your router: Step 1 Log into the web-based configuration of your router by opening a web browser such as Internet Explorer or Netscape and enter the IP address of the router (192.168.0.1). Enter admin for username and then your password (blank by default). Configure the WAN side to use PPPoE. Please consult your manual for login instructions since all routers are not the same. Step 2 Enter your screen name followed by @aol.com for the user name. Enter your AOL password in the password box. Step 3 You will have to set the MTU to 1400. AOL DSL does not allow for anything higher than 1400. Step 4 Apply settings. Step 5 Unplug (turn off) the power to the modem and router. Wait 1 minute and then power on only the modem. Wait about 1 minute and then power on the router. NOTE: If you connect to the Internet with a different Internet service provider and want to use the AOL software, you can do that without configuring the router?s firewall settings. You need to configure the AOL software to connect using TCP/IP (LAN). Contact AOL for more specific configuration information of their software.
AOL DSL Plus
Internet connection provided by AOL DSL Plus
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
