I have a Brother MFC-440CN Multifunction Center. I am unable to print to it and I have gotten various display messages stating errors.It began with "Unable to Print 50," then after a trying to restart the printer (had to manually unplug it, ON/OFF would not function) and trying to print again a "Unable to Clean 50" appeared.
I tried following the instructions on http://www.fixya.com/support/t211210-brother_mfc845cw as other people with my problem were directed there, but I was unable to follow the steps and succesfully open the machine.
Now I am getting a "Unable to Clean 51" error. I followed another guide on this site and found that my machine says there is a "Machine Error 51."
More than likely you have a bad printhead, if its under warranty brother will pay to have it fixed, otherwise just play baseball with it and buy another one
in my printer brother mfc-7340 when i coping with machine after some time display will show print unable with error code 72 what i will do? plse tell me;
Error:
Unable to Print XX
Problem:
The machine has a mechanical
problem.
-OR-
A foreign objects such as a clip or
ripped paper is in the machine.
Solution:
Open the scanner cover and remove any
foreign objects inside the machine. If the
error message continues, do one of the
following:
?? (MFC-440CN only)
See Transferring your faxes or Fax
Journal report on page 139 before
disconnecting the machine so you will
not lose any important messages.
Then, disconnect the machine from the
power for several minutes and then
reconnect it.
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
error 51: problem with purge station or travel path way of printhead. You cant fix it by yourself.
If it is still in guarantee give it to a service dealer after calling brother hotline.
