Blenders Logo
Posted on Aug 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuse blew on my Oster BCVBO7 blender. Can it be
Fuse blew on my Oster BCVBO7 blender. Can it be repaired?
Oscar Agnes
Level 2:
Sergeant:
  • Expert 347 Answers
  • Posted on Aug 30, 2009
Oscar Agnes
Expert
Level 2:
Sergeant:
Answers
347
Questions
11
Helped
142865
Points
687
Replace the fuse with the same specs. if it blows again, there is a short on the circuit.
Where can I get a replacement fuse for my Oster precise blend 12?
Hello, Frances -
Your question landed in the Fixya.com category of Furniture. I re-categorized your question to the Oster Blenders category.
I found the following information regarding Oster blender built in fuses:
(Quote)
The built in fuse protection has kicked in. To turn the blender back on, first turn the control knob to "Off" and unplug the unit from the wall. Then remove the jar from the base and free the blade of any obstructions. Next, press the external resettable fuse button on the bottom of the base. Wait 30-45 minutes for the unit to cool.
(End quote)
Source:
https://www.oster.com/service-and-support/product-support/product-faqs/blenders/oster-versa/blenders-oster-versa-faq.html?faq=blenders-oster-versa-faq-Q-A-4
Question: My blender shut off during use. What happened?
If you try that possible solution and the blender still does not start, then . . .this is the link to the Oster Contact Us page:
https://www.oster.com/customerservicecontact?cid=contactus
At the very bottom of the page you will find toll free Customer Service phone numbers.
Or . . .
Fill in the form there, asking about the availability of a replacement fuse for your model of Oster blender, so that you can send an email message.
Best wishes.
No power light on the Oster 6700
Get it touch with a local Oster repair guy. Likely he can solve your problem, over the phone. You may need to take it to them.
Burnt smell on oster blender
If you have eelctric knowledge, disassemble the case and look for some corroded contact or cable.
You can follow some of these youtube tutorials or look for additional info by doing a Google search using terms
Youtube disassemble blender
iFixit Blendtec Total Blender Disassembly
How to open and repair Braun Hand Blender Part1
KitchenAid Blender Coupler Repair KSB5 Model
OSTER Blender Repair How to fix an broken driver
If you are not familiar with disassembling a blender but you feel you have the knowledge to do it, take a photo of each step so when you have repaired the problem, you should have no problem to reassemble it again
Sep 04, 2013 • Blenders
There is liquid leaking through the bearing on the base that adapts to the motor. Is there a service repair center in my area, my zip code is 60415?
Oster.com shows one Oster service center in Illinois:
(http://www.oster.com/ServiceCenters.aspx?state=Illinois)
Household Appliance Sales and Service 7034 North Milwaukee Avenue
Niles, Illinois
60714-3707
Phone: 847-647-8250
Fax: 847-647-2214
It's a roughly 45-minute drive from your zip code, according to Google Maps. You may want to call them with a description of your problem and see if they can service. There are also several locations in PA that will service Oster blenders.
Blender 6812 does not start at all
Flip it upside down and take the bottom off and look for a fuse.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
1helpful
HOW DO I REPLACE THE FUSE ON AN OSTER BLENDER MODEL 4094
unplug it.... use a small plastic screw driver or even a metal one if you are careful... pry gently up on one side of the fuse... it should pop out of the holder. when it does... use your fingers to grab the end and pull up. the fuse is replaced by placing it back into the holder and pushing down until each end pops back into the holder
2answers
Lost blender fuse
There are no service manuals available for this model. If you can figure out what fuse it takes, Radio Shack most likely has them. What are the specifics?
volts
amps
watts
It can be figure with the electrical information. You will still have to get the right physical size though.
2helpful
6answers
How do I replace the fuse on my Oster Blender?
I just had the same problem too and ordered the fuse online with the link above. Thanks lele44!
The four feet on the bottom are easily removed with a 1/4" socket slipped inside the each rubber foot fitting.
I'm glad I found you. I saw some downright horrible reviews of my local Oster appliance service center here:
http://www.insiderpages.com/b/3723327730
Rob
Top Blenders Experts
Mike Cairns
Mike Cairns
john h
ADMIN Andrew
ADMIN Andrew
Are you a Blender Expert? Answer questions, earn points and help others
