I was filming the sun last month with my Sony FX7. And now the camera films everything darker. I tried all the different settings but its still very dark. Did I burn out the CCD sensors?
Burns?? could it be that what your seeing is a "corona" (brown ,with white and orange ) if so I bet your film compartment is letting in light , this happens on vintage equipment because they used velour type material as seal on film door and other places and it drys out over time and allows light in
also is your shutter working properly ??(clik don't mean working) a mt camera with film door open shown toward light source shouldn't allow light thru , wouldn't be the first vintage shutter that ive ever heard of sticking
Okay. One of my higher end Video camera's got the same problem after I filmed a gorgeous sunset for several minutes. Pointing at the sun for the extended time fried the camera lens and the sensors. (I knew better, but the beauty of the sunset made me a little crazy, and I just kept filming it.)
I called the camera company (in my case it's Sony), sent it in, and they are fixing and refurbishing the camera. It will be in "like new" condition when it comes back. The repair for mine is over $200 (closer to $300, actually).. but is well worth the investment, and I expect to have good performance from it for several more years, as opposed to spending a few thousand to replace it.
Polaroid announced several months ago that they would discontinue manufacturing instant film. This is because of their move to digital cameras. If you really are in need of this film, some may be available from peers on EBay, but Polaroid itself no longer manufactures it.
No I wouldn't say there is anything wrong with your DSLR I would think that the flash sync speed is set incorrectly. Each camera model will have a specific shutter to flash synchronized speed. I've had and used SLR cameras with sync speeds as low as 1/30 and DSLR's at 1/250. With my studio camera under studio strobes with a shutter speed at 1/60th I do get a slight blink of light BUT, it's the flash duration that makes the exposure. There is also a difference between a flash made for a film camera and one that is made for a digital camera check make sure teat the flash is compatible with the camera you are using, also check see what the camera syn speed is and set your shutter speed to that. If your camera is equipped with an "M" mode then it also has a "P" mode for program this is a common mode to use flash because the camera sets everything for you all you need to do is compose, focus and trip the shutter. If the exposures are not coming out right then another thing may be a factor and that's the light metering mode (if you camera is equipped) look in your manual there could be as many as four different metering modes, check to see what the manual recommends for flash photography for your camera.
Another thing I use digital flash on my film cameras BUT not a film flash on a digital camera they just don't sync right.
You should check and see if your night shot is on. That would definitely make the screen go completely whit outside but work fine inside. Hope that helps.
you need to go to the service center for replacing the
ccd image sensor...i know it is free for replacing that image sensor
cause your camera is one of the recall product due to the production
error of the image sensor...log on to the sony site and go the costumer
service cause the free replacing of that part will be expired now..
Look for the output jacks on your camera, hook them to your computer's audio/video input. Try accessing the recording utility on the computer then upload footage through NTSC format. You can then edit the footage. If your camera and computer utilize S-video, use them for best resolution
