Question about Panasonic Video Cameras
Charger Kit for Panasonic SDR-H85 - Panasonic Video Cameras
6ya staff
SOURCE:
VinayT
Vinay Tevatia
  • 1884 Answers
SOURCE: Without a panasonic SDR-S7 charger...
Yes as long as the input, output, attachment and the frequecy are the same
Posted on Aug 07, 2009
drifterK
Catalin Turcu
  • 4924 Answers
SOURCE: just brought a new panasonic
this happens if the camera was set to record in a different TV system than the one that the computer operates..Look into the camera menu and change the shooting mode from PAL to NTSC or the other way around..after that all the new footage will be import-able..
for the ones you already have read this article for the instructions..
This can be happening cause you bought the camera from a different country that uses the PAL system and in the US the NTFC system is used...
here is the article to make some light on how to convert and use the other ones..
http://www.digital-digest.com/articles/Convert_PAL_NTSC_DVD_page1.html
Posted on Dec 26, 2010
Shane
  • 668 Answers
SOURCE: software for installing panasonic SDR-H85
There is no download available for the driver for the camcorder. You can transfer photos from the memory card to computer.
Follow the steps to copy pictures from SD card to computer:
Connect memory card reader to your computer through usb.
Then select the pictures which you want to transfer to computer.
Then copy the pictures and go to the directory in computer where you want to save it.
That's it, you have uploaded the pictures from the memory card to computer.
Hope this helps.
Shane
Posted on Apr 04, 2011
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: how to delete files form
you will need to connect your camcorder to your computer
click start click on my computer to open from there you should see your camcorder then right click to select open you should see the data/files in there select what you want to delete right click select delete or you can right click select format this will delete all data on hard disk
hope this helps you
Posted on Sep 08, 2011
candisoden0
CecileSonr0
  • 3 Answers
SOURCE: oo.comhi. if i delete my
Here are several simple steps for you to take your deleted hard drive files back:
1). Stop using this hard disk drive in case that anything new can overwrite your original drive data.
2). Check your drive data backups to see how many of your original stuffs could be directly copied back.
3). Apply hard drive deleted file recovery software to scan this hard drive to see whether all rest drive data could be restored latter.
4). Back up all restored data on another drives or locations, not the same hard disk.
Read mode information here:
Hard disk lost data recovery
Make drive data backups well and also update them regularly in the future.
Posted on Dec 19, 2014
I have a Panasonic SDR-T55P video camera. The battery seems to be good but the unit turns off immediately after the viewing window is open (red light is on for a few seconds). Any advice?
WHAT MESSAGE IT DISPLAYS ON SCREEN? OR WHAT IS THE RED LIGHT? IS IT THE SAME WHEN IT RECORDS?REMOVE SD CARD AND TRY USE EXTERNAL POWER SUPPLY BUT BATTERY MUST BE PANASONIC ONLY AS I SEE IT ON THE MANUAL HERE...About batteries that you can use with this unit
SDR-S50
SDR-T55
The battery that can be used with this unit is VW-VBL090/VW-VBK180/VW-VBK360.
SDR-H85
The battery that can be used with this unit is VW-VBK180/VW-VBK360.
The unit has a function for judging whether the battery can be used
SDR-H85
safely, and only dedicated batteries (VW-VBK180/VW-VBK360) support this function.
Only batteries which are genuine Panasonic products and batteries from other
companies certified by Panasonic can be used. (Only batteries which support this
function can be used) Note that Panasonic can only guarantee the quality,
performance or safety of genuine Panasonic batteries and not those made by other
companies.
It has been found that counterfeit battery packs which look very similar to the
genuine product are made available to purchase in some markets. Some of these
battery packs are not adequately protected with internal protection to meet the
requirements of appropriate safety standards. There is a possibility that these
battery packs may lead to fire or explosion. Please be advised that we are not liable
for any accident or failure occurring as a result of use of a counterfeit battery pack.
To ensure that safe products are used we would recommend that a genuine
Panasonic battery pack is used
The unit has automatically detected an error. Restart
the unit by turning off and on the power.
? Repair is needed if it is repeatedly displayed even if
it is restarted. Detach the power connected, and
consult the dealer who you purchased this unit from.
Do not attempt to repair the unit by yourself.
Feb 26, 2015 | Panasonic Video Cameras
Tip
Convert/Import, Edit Panasonic SDR MOD Files to Mac, iMovie, FCP
Panasonic SDR camcorder mainly contains SDR-H and SDR-S two series. Most Panasonic SDR series camcorders record videos in MOD MPEG-2 which is a standard definition video format, such as some popular Panasonic SDR camcorders: SDR-S26, SDR-S10, SDR-H60, etc. However, there are also some Panasonic SDR camcorders recording videos in AVCHD /MPEG-2 like Panasonic SDR-H86, SDR-S45, SDR-T56, etc.
To get more details of Panasonic SDR camcorders, you can check the list of most popular Panasonic SDR series camcorders as follows:
Panasonic SDR-H Series: SDR-H18, SDR-H40, SDR-H60, SDR-H80, SDR-H85, SDR-H81, SDR-H86, SDR-H200, SDR-H80S, SDR-H80K, SDR-H80A, SDR-H80R, etc.
Panasonic SDR-S Series: SDR-S10, SDR-S26, SDR-S50, SDR-S45, SDR-S150, SDR-S25A, SDR-S26K, SDR-S26R, SDR-S7K, SDR-S7A, SDR-S7R, etc.
Panasonic SDR-T and other Series: SDR-T50, SDR-T55, SDR-T51, SDR-T56, SDR-T50K, SDR-SW21S, SDR-SW21D, SDR-SW21G, SDR-SW20S, etc.
"I have a SDR H85 panasonic camcorder and can't seem to get the videos to download on my mac. Any suggestions?" ---from Yahoo Answers
Actually, for Mac users, you may have these similar problems when you want to import Panasonic SDR video to Mac, or edit these video in iMovie, or FCP, FCE. Because some Panasonic SDR series camcorder are not compatible with Mac, so you cannot directly import these camcorder videos to iMovie, Quicktime, or FCP . See here to know iMovie '09: Camcorder Support http://support.apple.com/kb/ht3290
Now, a professional Panasonic SDR Video Converter for Mac is specially designed to convert MOD(MPEG-2) to MOV, MP4, AVI, DV, H.264, 3GP, 3G2, M4V, WMV, MKV, etc on Mac. It supports converting MOD, TOD, AVCHD MTS/M2TS, etc to Mac, iMovie, Quicktime, iDVD, FCP, FCE, iPad, iPod, iPhone, Blackberry, PSP, and other popular mobile phones. This Mac MOD Video Converter can also help you extract audio from your Panasonic SDR videos to MP3, MKA, WAV, M4A, AC3, OGG, AAC, WMA, etc.
Instruction for you to convert Panasonic SDR video to Mac, iMovie, FCP, etc step by step
Step1: Install and Launch MOD Converter for Mac
Step2: Add Panasonic SDR Video on Mac
Click "Add File" to upload your chosen Panasonic SDR video to Mac MOD Video Converter after you launched it.
Step3: Set Output Video Format for Mac, iMovie, Quicktime
Click "Profile" to open the Profile drop-up list to select MOV, or MP4 as output video format for Mac OS, Quicktime, iMovie, FCP, FCE, etc.
Step4: Convert Panasonic SDR Video to Mac
Press the "Start" button to convert Panasonic SDR MOD/MPEG-2 files for Mac, iMovie, Quicktime, FCP, etc. After conversion finished, you can edit converted Panasonic SDR videos with iMovie, FCP, FCE, iDVD, etc.
More details: If you want to convert Panasonic SDR AVCHD/MPEG-2 files to Mac, you can click here to get more info of AVCHD Converter for Mac.
Related: How to get video off camcorder to Mac OS?
How to convert AVCHD m2ts/mts/ts files to MP4, MOV, DV, etc on Mac?
on Nov 05, 2010 | Computers & Internet
Is there a software download for VideoCam Suite 3.0 For Windows 7 64 bit?
This link does not work anymore. Any other thoughts on how to get a copy?
Jun 08, 2012 | Panasonic SDR-H85 Silver 80GB Hard Disk...
I have a panasonic sdr h85 i cant download my videos to my computer i do not have a software disk could that be the problem if so how could i get a software
-Are you using a memory card? Check "my computer" for removable drive and look for folder(s)
-Are you direct connecting via usb connection?
May need to wait for driver(s) to load to enable viewing.
What windows are you using?
Try this page: http://www.megaupload.com/?d=2U85KF1Y
Click on "Regular Download"
It's a .rar file so you'll need winrar to decompress it. Send me a personal message if you need help.
Jan 11, 2012 | Panasonic SDR-H85 Silver 80GB Hard Disk...
How to delete files form my sdr-h85
hope this helps you
Sep 08, 2011 | Panasonic SDR-H85 Silver 80GB Hard Disk...
Panasonic SDR-H40P Hard Disk Video Camera loses focus
Keep it still roughly 5-6 seconds in the same spot and it will re-focus
i had that once
Sep 06, 2009 | Panasonic SDR-H40 HDD Camcorder
Video Cameras Logo
50 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
