Question about JVC Everio GZ-MG130 Camcorder
Horizontal White Line
There is a horizontal white line that is permanently there across the screen when the camcorder is on... how can I fix this...?
  • Jacob-Dylan Dec 04, 2007
    It's new though... and has hardly been used. I guess I should take it back then.
    Sergeant:
    Champion:
  • 270 Answers
May be the begining of screen failure
Posted on Dec 03, 2007
6ya staff
SOURCE:
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
JVC Everio GZ-MG130 Camcorder Logo
309 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
