Samsung Tocco Ultra Cell Phone Logo
Posted on Aug 22, 2009
The screen has gone darh, not showing anything but
The screen has gone darK, not showing anything but still sensitive. The phone still rings and can receive calls.
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Aug 22, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
2786
Points
41
your phone's display had gone.. i also faced this problem earlier.. so there is only one solution, change your display
thank you...
I cannot slide open my LG phone. I hear my Messages but can't open the phone, no matter what
What is your phone model?
These answers were given assuming that you're using a LG smartphone with a touch screen :
Scenario 1 : Can you see the screen lights up and any sort of graphical image when you hear incoming message ?
A : If you can, and still you cannot slide unlock, your touch screen has gone. Get a replacement touch.
Scenario 2 : You cannot see anything on the screen. It stays dark when you hear incoming messages/calls
A : Your LCD has gone. A replacement LCD or a Touch/LCD combo would fix the issue.
I hope you saved your back by either way.
Motorola A780: screen has gone dark. Can hardly see anything on the screen
The fault is from either the flex that connects the screen to the phone's main board or the fault is from the screen itself. You need to take your phone to a technician for check up so that you will know specifically where the fault is coming from.
Best wishes
We have a Samsung U900 - intermittently the screen will turn dark blue and not show anything, though you can phone and receive calls, etc. The screen just doesn't show anything. What can cause this and how...
Here's a link to a possible solution; http://www.iusermanual.com/cell-phone/samsung-flipshot-sch-u900-cell-phone-user-manual.htm
you can download the manuals.
Hope it helped you!
Dont forget rating.
Will not switch on, display lights, but no PIN request appears.
dear,
if it shows logo only then u have to reformat your phone and if it doesnt show anything except white screen then try to call on that set if the ringer rings and the call is listen then its mean the lcd is gone ..you have to change it..
goodluck...
Jul 10, 2009 • Siemens S65
1helpful
Samsung LCD TV Screen is very dark but still shows picture
You either have a bad Power Supply or a bad Main bd. Worst case can be the inverters on the Panel have gone bad in which case the Panel needs to be replaced.
5helpful
2answers
Iphone Screen not lighting up
If you are using a case, the iPhone 3G and original iPhone cases are not compatible, so it may be covering the proximity sensor. If you have a case or something else on the phone, try taking it off. When the proximity sensor detects something covering it, the screen will go off to help preserve battery life (such as when the phone is up to your face) however if a case is covering it, it will assume that it still needs to be off.
1helpful
I cant see anything because the screen stays black
Without knowing your model of phone it probably needs the firmware updating or, more likely, the backlight on the LCD screen is knackered. To test, turn on your phone in a dark room and shine a torch onto the screen. If you can see some of the screen then the bscklight has gone. Also try connecting the phone to your PC & updating the firmware.
Jul 26, 2008 • Cell Phones
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
