Question about Sylvania Televison & Video
I have a Sylvania modle number lc321ssx when turn on green light blinks then back to red light can anyone help me plz
6ya staff
SOURCE:
Anonymous
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
rockitman187
Randy Hough
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Posted on Sep 14, 2009
Testimonial: "You are on the right track even with my poor explanation. Thank you"
EZ456
  • 225 Answers
SOURCE: When i turn my ps3 on it turns green then it turns a yellowish-red color then blinks red what do i do?
Yes this sounds like the YLOD - caused when the GPU and the CPU overheat - you can send it in to fix but they will charge you for this. Or you can fix it yourself from home with a good repair guide.
CLICK HERE FOR A GOOD REPAIR GUIDE
Posted on Nov 27, 2011
How do you fix a flashing green light and no picture or sound?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Sylvania Televison & Video
Tv turned off. Will turn on to standby light. Green powerr light flashes and then tv turns off back to red standby light. No picture. What to do?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 26, 2015 | Sylvania LC420SS8 LCD TV
Green light flashes back red
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sylvania LC420SS8 LCD TV
Sylvania lc321ssx green light comes on than turns off
POWER BOARD NEED CHANGE ELECTROLYT CAPACITORS
Oct 31, 2013 | Sylvania LD320SSX LCD TV
Tv will not turn on
well i have the same the proble with my sylvania plaza t.v however when i plugg it in into the socket the red light blinks then the green light comes on but then it just turns off completley...and the red light is still on ? is there a way to fix this problem or is the t.v permently broken??
Jan 13, 2012 | Sylvania LC225SSX LCD TV
Tv will not turn on
The green blinks are an error code indicating a specific fault, your power supply developed an 'over-voltage' issue and needs to be serviced at your local repair shop.......
Nov 02, 2009 | Sylvania LC320SS8 32 in. LCD Television
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Kdf-60xs955 red continous blinking lamp light
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Televison & Video Logo
57 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Caltronic TV Repair
Caltronic TV Repair
Level 1 Expert
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
