SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
SOURCE: LN-T4671F 46 in get loud clincking sound when tv
power supply is probably about to fail. will probably start to cycle on/off by itself.
SOURCE: My Samsung LN-T4665F LCD TV is slow to start.
You have bad caps.on the power supply. They are under rated, 10volt insted of 16volt or more. Caps.run about $2-3 each. usualy takes 4-6 of them. Or replace the whole power supply. But you will have the same problem in a couple of years. Best bet is to have the bad caps. replaced with the right voltage rateing,and you will not have to worry about it happening again. New power supply is...
BN44-00168A About $120 used-180new cheeper to repair.
SOURCE: samsung model LN-T4665F tv wont turn on just
Changed 3 capacitors .. cost me 5 bucks like new
