We've inherited a belling electric double oven. The bottom oven and fan dont work. When you turn the oven knob on it clicks but doesn't heat up. When you turn the fan on nothing happens. Any ideas ?
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
For all Free appliance repair videos visit our VIDEO
TUTORIALS1, If the Belling fan motorin the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter. To gain access to the BELLINGelement you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the elementyou will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the elementis open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine. 2, If your BELLING fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motoris working you will
see the blade turning fast if it is ok. if the element is heating but the fan motoris not blowing the heat into the oven then
you need To replace the oven fan motoris a little more
expensive and a bit more involved. 3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your BELLING oven thermostat 4, A quite common and easily overlooked answer is if your BELLING oven is not working at all ie:
no heat and no fan then the chances are that someone has put the oven timerinto AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
