Motorola Mobility RAZR V3x Cellular Phone Logo
Posted on Dec 03, 2007
My cell keeps shutting down when i try to turn it on
Hi when i turn my cell on it keeps shutting down then the screen goes white and charging battery comes on. I keep trying this but it won't stay the lights on the phone dies and the white blank screen appears. I even brought a new battery but this didn't help either...what do i do?
  • Anonymous Jan 09, 2008
    i have the same problem and sadly don't know what to do
  • PASTORLOVE Jan 10, 2008
    I HAVE THE SAME PROBLEM. RAZOR ARE NO GOOD I ONLY HAD MY PHONE FOR 6 MONTHS. I CALL SUNCOM THEY SAY I WILL HAVE TO PAY 100 DOLLARS FOR ANOTHER PHONE BUT, I ONLY PAYED 50 DOLLARS FOR THE PHONE. I GOT INSURANCE THAT DONT COVER NOTHING IF ANYBODY HAVE A SOLUTION LRT ME KNOW
A
Anonymous
I have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
2answers
My Samsung Galaxy Infuse won't turn on or charge.... it just keeps flashing the Samsung screen and then the Roger's screen. Is it my phone, or my battery that needs fixing?
Have you tried a hard reboot? Hold down the power button, don't click on anything on that screen that pops up, just keep holding the button down until it reboots on it's own.....
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
Blackberry screen keeps turning white but is alright when i charge it
It sounds like you're having problems with your processor. I would take it into a repair shop
2answers
My blackberry curve screen keeps turning white
hi jst try this get a new battery or give it for sevice
4helpful
My HTC HD 7 phone keeps turning off it goes to the white screen with green HTC then shuts off and keeps doing the same thing over and sometimes when i try to use it and i tap the screen then it shuts off...
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET: Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware: 1) Turn off phone 2) While holding down both the Up/Down Volume buttons, turn unit on 3) Keep holding down the volume buttons until white screen appears 4) Press the Down Volume button to reset to factory defaults. 5) Restart phone
My phone runs out of batteries so i took it home to charge it but it wont turn on, everytime i try it goes to a white screen as if it loading then shuts down again what do i do
if you have a usb charger for the pc you can do a trickle charge which helps when it goes fully dead another way that sometimes works is plug it in and while its plugged in remove the battery and reinsert in while its plugged in sometimes it allows it to charge.
White screen when turn on then it turns off
Hi, Make sure the battery is fully charged. Second try resetting the phone by removing the battery and memory cards, If it has reset button push that instead. If this doesn't work I would call your service provider.
3helpful
PHONE WON'T Turn On
when this happens, does your phone have enough battery charge? because if it's not fully charged, as you switch it on, you will only see a white screen and then it will shut down. try charging it first with your cell phone is turned off. then after charging try to turn it on. if it does and you only see a white screen, the problem is the LCD. go to the LG dealer and have it reset. that wil surely solve your problem not unless you sat on your phone or you dropped and broke the LCD. hope this helps. thank you.
LG cell phone
hi there
hav your phone serviced. that has an issue internal. they might have to replace some chips for that. youve checked the battery and still does the same thing.
hope this helps.
fixya!
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
