My iBook is running OSX (10.2.4) It sees the router but the passkey does not work. The same passkey works on all my other devices. My iBook wont connect to my Linksys wireless G router. Any help would be greatly appreciated.
What type of security encryption do you use? I had an Acer Aspire one that would not connect when I was using WEP encryption, but when I went to "no security" it connected fine. Later I discovered that I could use WPA2 encryption and it worked fine with that. You might try removing the security just to see if that is where the issue is.
