HP Officejet 4110 All-In-One InkJet Printer Logo
Posted on Aug 21, 2009
All-in-one 4110 hp fax not working
Phone line is hooked up, put paper in to faxed and push star. all you get is beep,beep,beep.
I have even tried different numbers to fax to.
Anonymous
Level 1:
  • Contributor 61 Answers
  • Posted on Aug 22, 2009
Anonymous
Contributor
Level 1:
Answers
61
Questions
0
Helped
15596
Points
93
What kind of connection you are using, I ment broadband or some other
I place my paper that I want to fax in the fax machine,dial the number that I want to fax, push start, it scans the paper, I hear the fax tone and at the end I get a Beep Beep Beep and the report sending...
1) did you dial correctly?
2) are you in an office or in your own home?
a) if you are in an office, you may have to dial a 9 or someother number to dial out before you can type in your original fax number.
b) if you are in your home, then its a number of things: Fax machine not connected with phone lines properly is one big supect. Check your phone cables to make sure that the fax machine is properly connected.
Di i put paper to be copied for faxing in face up
Hi there
On most fax sending I know is always face down but being not sure of all printers I but a manual for you to have, if not sure send a fax to some one you know one way and then the other way, and just ask them each time after sending did it work.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/HP-Officejet-4110-Manual.pdf
You will need an adobe reader to see this file if you not got a Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
I can't fax in our out...Don't know about set up
The fax phone line goes to LINE Port
Answering machine goes to TEL Port
1helpful
2answers
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
Off hook message
Make sure you are plugged into the LINE port and you are not sharing the phone line with a computer.
HP 4110 OFFICEJET ALL IN ONE
Hi red,
You may need to set the fax as the default answerer of incoming calls. Here's a little tip, most local phone companies offer a distintive ring feature that only the fax will answer. If you get the option your users manual will tell you how to set up this feature and whats neat about is you get a seperate
number for that feature, your own dedicated fax line without add any extra outside lines.
anaanymous
4helpful
3answers
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Can't receive fax - fax rings 2ce then just stops / says phone off hook
Hi Iryan,
Instead of switch box, a more dependable option is to get a distinctive ring. Your local phone company offers this option. What's neat about is you get a seperate fax number. Its like having a dedicated fax line without adding extra lines to your service. I think the monthly fee is around 3 dollars a month for this feature, but, believe me its well worth it.
anaanymous
k24674
Grand Canyon Tech
Grand Canyon Tech
