Hi Ross,
The error code E A on your Smeg induction cooktop indicates a communication error between the electronics of the cooktop and the specific burner. This could be caused by a fault in the electronics of the burner, a wiring issue, or a problem with the main control board of the cooktop.
You can try to reset the cooktop by turning off the power supply to it and then turning it back on after a few minutes. If the error code persists, it is recommended to contact Smeg customer service or a certified technician for assistance in diagnosing and repairing the issue.
Every time you try to light just one burner the ignighter will try to light them all. The reason why is that they are all wired to the same switch under the cook top. There is nothing to be worried about. That is the way the factory made the cook top.
the ignitors have got wet usually due to cleaning. they are usually located under the rotating switches
just let them dry out ( very well .....may take days)
and it will work normally again
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
