Washing Machines Logo
Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag top loader on final spin cycle leaves the clothes soaked
Maytag top loader on final spin cycle gets the water out but clothes are still soaking wet. Sometimes I will rotate dial back to beginning of final spin and try it again and it gets em dry but last time I tried this several times and it they were still dripping wet when cycle finished. thanks for any tips here....
fixrguy
Level 3:
  • Master 415 Answers
  • Posted on Aug 20, 2009
fixrguy
Master
Level 3:
Answers
415
Questions
0
Helped
82611
Points
1311
How much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
1helpful
Maytag bravos mct washer keeps filling with water on drain and spin cycly
first thing to do is a reset. unplug it for 5 min and plug back in to see if it resets to factory settings.
I have a Maytag Bravos top loader washer and it seems to agitate during the washing phase but when it comes to the spin cycle the water drains but the clothes are still soaked at the end of the cycle, as...
This happens to me to. It is because it believes it has gone out of balance and has stopped and gone ahead and timed out making you think it has completed it's cycle. I do not have a solution to this other that I am thinking of chucking this washing machine out the door and buying an older machine.
Washer works on every setting but does not spin on spin cycle
IF ITS A TOP LOADER ITS POSSABLE YOU HAVE A BAD CLUTCH IT A FRONT LOADER YOU MAYBE USING TOO MUCH SOAP
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
2answers
The machine wont spin
it sounds like faulty timer its were the big dial is at ,you may need to call service to repair it sorry its no easy fix.
2helpful
Will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Front loader washing machine is not draining
Hi Is this a whirlpool? Sounds like something is in the pump or the pump is bad.
Get me model # and I can help you further. Thaks
Vic
1helpful
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
1999 Maytag Neptune front loader
Have you replaced your 12002535 door latch wax motor if you have a MAH3000, MAH4000, MAH5500A or the 2000 stacker? These wax motors will eventually fail on every Neptune shipped. When the wax motor fails the upper machine control board be damaged and you will lose your spin function which leaves your clothes soaking wet. There is a website that offers a repair kit to see if your control board is useable again. Don't keep starting machine because you might cause further damage to control board and the motor control board located near the floor until you see if R11 is burnt on the upper machine control board located behind the timer.
See www.neptunewaxmotor.com for more details and step-by-step disassembly photos.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
