There are 2 different hinges listed Scanner hinge and Base Hinge.
Scanner Hinges left and right are the same Part # is LE9815001
Base Hinge Left is LP0018001
Base Hinge Right is LE6245002
I hope this helps you to determine which one you need. The scanner hinges are the ones that connect the top platen to the machine and the base hinges are the lower ones that allow the machine to open up clamshell style.
Right hinge is LE6245002, left is LP0018001
SOURCE: Problema con impresora MFC-3420C
Hi there
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
SOURCE: MFC 3420C. I am getting error 41
While there are many ways to prevent Brother printer error code "41
