Sounds like a thermal switch which controls the hot surface light is stuck closed.
If this is a new unit, I'd return it. If not, I would check the switche(s) for the hot surface light -- when the unit is cold, unplug one wire going to the thermal switch and check it for electrical continuity. If you get current from a multi-meter through the switch, replace it -- it's not opening when it cools down.
Charlie
Here is a tip that I wrote about the problem of the cooktop light staying on.
Oven Hot Surface Indicator Light stays on
heatman101
