Question about LG Computers & Internet
Hello Sir, I have a LG X130 notebook and that stuck on LG Logo screen. and restart frequently at same screen. i tried removing the CMOS and reinstalling it again, that didn't solve the problem.
It didn't allow me to go on bios setting and boot option. Today i tried removing Hard disk. now i can go on BIOS setting as well boot option. but when i insert the HD back, again same problem happen. i tried another hard disk but unluckily same problem.please help!
    Sergeant:
  • 286 Answers
It's may be error of the hard drive. therefor remove and reconnect ,if not fix pls connect to another pc and test. or replace the hard drive.
Posted on Oct 11, 2019
  • Dilum Senarath
    Dilum Senarath Oct 11, 2019
    it's may be error of the hard drive. therefor remove and reconnect ,if not fix pls connect to another pc and test. or replace the hard drive.
6ya staff
SOURCE:
danasaur
Dana Stienheimer
  • 77 Answers
SOURCE: Toshiba Laptop A60-S166 fdisk won't recognize hard disk?
Hmmm. Unusual report, "secondary optical disk". Sounds like you have a primary and secondary IDE setup. Something desktops had, but rare for laptops. Because of this, I would try setting the HD to "master". Most IDE HDDs have some extra pins beside the IDE pins, 4 or 6 pins in a separate compartment, same side as IDE jack. These are for choosing "master", "slave", and (default) auto detect. To find out which pins must be connected, look for a diagram on the lable or side of HDD. If none there, look up the specs on your HDD at the manufacturer's website. If all fails, It does not hurt to use "trial and error" on these pins. Either BIOS will be happy, -or ignore the setting. Try again until you find the right one. You need a small jumper to try this. If you are VERY careful not to wrap more than two pins, you can do this with a single wire from a copper stranded wire. Use hemostats and clip the excess off clean. Use a magnifying glass to verify it only touches (connects) two pins.
Personally, I would try THIS first, but it will cost you a bit of money... Buy an external IDE HDD case, with USB connector, insert your HD, plug it into a desktop PC, mount it, and use FDISK there. Always better to format a 2.5 inch drive via ext methods. Avoids funky BIOS corruptions, wacky 8mb Toshiba "recovery partitions" and MBR viruses. Also avoids the LBA limits many older laptops have, if YOU format the drive externally. This can also be the only problem. Not jumpers, but format methods. If the laptop is older than 3 or 4 years, I would suggest restricting ALL partitions to FAT32. Maybe C, D and E. Afterwards, the external USB case is a GREAT device to have, for exporting/storing large files from your laptop.
Let me know how it goes
Posted on Feb 11, 2008
Anonymous
  • 58 Answers
SOURCE: Error 0x400 100 130000 1002 while restoring factory image HP
I am assuming you are trying to reinstall Vista. Apparently, HP's recovery partition is less than perfect and the recovery disc you created is probably worthless. (and you can NOT make another one, they only let you make one!) You are not the only person to have this issue.
Here are some things you can try:
1) Borrow an OEM version of Vista from someone...anyone. It sounds like you are proficient with PC's and maybe you know someone who works in IT. Use your product key (25 digit key code) and you should be able to reinstall.
2) if you like Vista, buy yourself an OEM version. It will not have all the factory (HP, Dell, Acer, whatever) BS on it. It will positively work because your hardware if fine.
3) Put XP on it. Personally, I think Vista is a mess. Microsoft is working on "OS7" and soon Vista will be like "Millennium".
Sorry it's not an easy fix, but glad your hard drive and memory show no errors.
Posted on Mar 29, 2009
Anonymous
  • 16 Answers
SOURCE: How to install Windows Xp on Compaq Presario CQ40 Notebooks ?
i have succeful install windows xp into compaq presario cq40 with this windows xp disk .It diffrent compare to other windows xp.it support compaq presario cq40.100% working for all compaq presario cq40.
Download link:
http://rapidshare.com/files/.../Windows_XP_SP2.part1.rar
http://rapidshare.com/files/.../Windows_XP_SP2.part2.rar
http://rapidshare.com/files/.../Windows_XP_SP2.part3.rar
http://rapidshare.com/files/.../Windows_XP_SP2.part4.rar
http://rapidshare.com/files/.../Windows_XP_SP2.part5.rar
http://rapidshare.com/files/.../Windows_XP_SP2.part6.rar
Posted on Sep 21, 2009
Jason Smith
  • 102 Answers
SOURCE: How to reset bios password
I fix laptops and when I get an Acer laptop locked with an unknown bios password I use www.unlockbiosrecovery.com to get the bios master password for only $20 which clears any set bios password and they guarantee it to work. I have unlocked a dozen or so Acver laptops with unlockbiosrecovery.com bios password recovery service.
Posted on Sep 01, 2011
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
Posted on May 27, 2012
WHAT IS THE F KEY TO BE USED IN MAKING A FACTORY RESETTING FOR LG X130 NOTEBOOK
The F11 key after POST will activate the system restore function.
Jul 24, 2014 | LG X130 Netbook
REFORMAT LG X130
F11 whilst booting should get you into the Factory Restore program.
Mar 25, 2014 | LG X130 Netbook
LG Netbook X130 stuck at Logo screen
remove your hdd and replug check data cable and power cable
Feb 27, 2014 | LG X130 Netbook
There's a sound during startup
There is no problem with your computer. It's just natural to have a beeping sound during start up. If there is, then it will show an error message in the screen.
If it's just a short beep, then it's normal.
Carlo
Jan 23, 2013 | LG X130 Netbook
Lg x130 no audio device found
Here are the drivers. Choose OS and look for Realtek. Best of luck installing.
http://www.lg.com/ae/support-product/lg-X130-L.A7W1E
Sep 27, 2012 | LG X130 Netbook
To download smart cam in Lg X130 notebook PC for Free
lg x130 notebook laptop camera 1.3 mega pixel setup need
please send to me setup.
Sep 04, 2012 | LG X130 Netbook
Hi, when I turn on my Acer (aspire 5741 series) laptop it gets stuck on a screen with the acer logo, & says 'press F2 to setup' in the corner. If I press F2 or any other key, the computer just beeps....
This may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Try removing any newly installed Hardware, if still not working, goto CMOS setup, press F9,if asked, press Y and then F10 and then Y. If still not working, try Formating the C drive, your windows file are corrupt.
Nov 11, 2010 | Acer Aspire 5100 Notebook
My LG flame phone is stuck on the "hello" screen. I took the battery out and restarted it multiple times hoping to fix it, but still it gets stuck at "hello"
look sir you cellphone is over loaded by too much data take its memory card out reformat it and then turn it on without memory card..after it gets start then put in the memory card ...........thank you
Jul 04, 2009 | LG Flare Cellular Phone
HP Pavillion dv6700 won't load up - gets stuck on logo page
i afraid that cause by hardware, but try to remove battery and only use the power. or press F2. if prsseing f2 the new screen(bios) open try restart and press F8. tell me is it work or not
Jan 28, 2009 | HP Pavilion DV5234US Notebook Laptop
Computers & Internet Logo
19 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
