All, just figured something out. I had the evil beeping problem as well. I decided to play around and see if I could fix it. I unplugged the iFit adapter from the main control board and when I plugged it back in and tested it, IT WORKS AGAIN! NO MORE BEEPING!
my ifit on my c2400 is soldered to the main board. I too have beeps that are deeper in tone when the treadmill is inoperable. This random thatit is this way, not every time I use it. Should I remove the Ifit feature? reply to [email protected]
I had the same problem with my Nordic track. I pressed every button until I found the one that did not beep. The one that does not beep is stuck. My problem was with the Ifit button. I disconnected the Ifit unit and now the thing work fine except for Ifit which I never used. Nordic track wanted to sell me a new console which cost more than the machine.
How did you disconnect the Ifit unit? I am having the same problem.
Steven - Your trick worked! Unplugging the iFit adapter from the system board worked like a charm!! Thanks!
I just fixed my elliptical thanks to you Steven!!! You are a lifesaver!
I had the same problem. I have a C 2155 NordicTrack it would give me for beeps with every control I hit. NordicTrack told me it was the console, or the control wire. The console cost almost as much as the machine. After reading this, I disconnected the iFit, and the machine works perfectly. Thank you for all of your help. Gratefully yours, JG. [email protected]
4. Not for
wow, such an old thread and it just helped me. Dreadful beeping and no response. After unplugging the iFit module everything back to normal. Cheers to those who posted this.
Thanks! This helped me too. Have a 2nd hand A2250. My iFit connection was glued to the board, so I just cut it, taped off the cut ends with electrical tape and that did it. Never once used iFit anyway.
I have Nordic Track A2550 the ribbon cable is soldered onto the board on both sides. I tested the ifit down switch (one that is not responding with beep when pushed) and the switch is good. I cut off the ribbon cable and my A2550 is back and running
Is it one beep or multiple beeps?
Im afraid your motor may be shot.
Thanks
ok - then the controller is shot.
CLICK HERE for your manual in PDF format.
You have the KeyClip installed?
Is the machine plugged into a surge protector?
Simply plugging and unplugging it can cause a surge to the main circuit board and cause damage.
Have you reset the motor's circuit breaker (next to the power plug)?
Push and HOLD the stop button for 5 seconds. It may be in DEMO mode if the display remains lit after removing the key.
then its going back to a faulty controller pad.
depending on the environemt it was stored in for so long - it may be simply corrosion from humidity.
Remove the controller and look for any signs of rust, or blackening, or green patina.
Unplugging and re-plugging in the connectors is also suggested.
Could you send me email to [email protected] if you fixed this problem. I have the same problem with my c2155
I am having the same problem with my c2500 and I understand it the console is bad...
The model number is located on the front cover of your manual, and on the serial number decal. Please send the info so I can get manual.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
First of all you need to check the belt, try to adjust it counterclockwise, opposite side about one full turn. if further you have the same problem means you need to change the console electronics it cost approx 100 usd.
Post further comments for more information....
Good Luck!!
Thanks
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
belt adjusted, no change.... this is something else, as the fan button only beeps when we push it. every button just beeps.... , raul
this didn't work, all the buttons just beep when pushed, even the fan
i adjusted the belt to non avail. all buttons do NOT work, just a beep each time....
ntl07707 nordic track c2155
ntl07707 nordic track c2155 is the model #
thx, raul
it's just a single beep. each time we press a button, we have a beep. there is a fan on it and when that is pressed it also beeps
raul
hello,
this treadmill has less than a mile of use on it. we originally purchased it about a year ago and just made sure it worked after assembly. 6 months later my wife said it only would beep. i adjusted the reed switch as the manual suggested and it worked once more. 6 months later she wants to use it and it does it again. this time adjustment of the reed switch doesn't work....
anything else you can think of??
thx, raul
hello,
unit is on surge protector. motor reset has been turned on and off several times. i took it off display mode after assembly. i also too the right arm off to verify the connector was connected correctyly. the light on the motherboard remains red which indicates the unit is receiving power...
thx, raul
