Battery full charge gas canister full fan comes on but will not fire nails
Check the date on the gas, if its out of date often my guns either want fire at all or only sometimes fire the odd shot.
Had same problem -followed paslode video to clean and lube.checked spark(ok) .reassembled still didn't fire. used screwdriver to make sure firing pin was all the way up. it moved up about 3/8", put full clip of nails in -bang! bang! bang!, huge relief. hope this helps troy.
I had new full gas bottle, with no pressure enough inside. Gun fired sometimes. Changed bottle, now firing well.
Probably needs cleaning. You`ll need two new o`rings.
Sounds like a battery contact problem or a bad battery..
Here is a tip that I wrote
about the Paslode nailers and the problems that can come up
with them.
I also have a link to the Paslode manuals
which contain Paslode cleaning and troubleshooting guides.
If
you need parts for your Paslode, there also is a link for a
site that sells the Paslode nailer parts.
Paslode
Cordless Nailer Problems
heatman101
with them.
If
Paslode
heatman101
