Question about Brother Sewing Machines
PC8500 tension issues w/ free motion quilting. Either tensions too weak/strong, or gathering up fabric. Moved cone feeder, re-threaded & reloaded bobbin over & over.
I find sweet spot & get tension right, start a project, but when I rewind more bobbins/re-thread machine, I cant get it right. Using Brother Free Motion Quilt Foot SA129, new 100% cotton mach quilt thread, & new quilt needle. Any ideas???
    Champion:
  • 222 Answers
The PC8500 does not do free motion well because of its tension design, it is not you.It was one of he earlier machines to set tension by the thickness of the fabric. If you really want to do free motion then it is time for a different machine.
Posted on Sep 12, 2019
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 53 Answers
SOURCE: Pfaff Select 4.0 has looping on bottom of fabric, free motion qui
Make sure your are lowering the pressure foot first before you start sewing. With the free motion foot, you still have to lower the pressure foot, this allows tension to be put on the top thread and allows the foot to work properly (when the needle goes down so should the foot and when the needle comes up it should lift the foot up.)
Also make sure your tensions are in a middle setting and that you are threading the machine with the pressure foot up.
The way to insure you will not get your problem is with the foot up, you should be able to pull the thread easily right before the eye of the needle and when you put the foot down you should then feel a fair bit of tension on the top thread.
hope that helps :)
chris
Posted on Jun 06, 2010
SOURCE: thread tension when free motion quilting
do you have this problem when doing regular sewing? if you do then the tension dial may be going bad & would have to be replaced
Posted on Mar 14, 2012
I have a Janome Horison Memory Craft 8900 SpEd, thread looping on backing side for free motion. DO i NEED Part No. 200-445-007 Janome Bobbin Holder for Free Quilting and Hand-Look Quilt Stitch.
Free motion quilting is a finicky function, much more than most other sewing. Since you are getting loops on the back of the fabric, try increasing the upper thread tension. Tension causes the top and bobbin threads to pull against each other. If the pull is not equal, the threads will be pulled to one side or the other.
If you continue to experience looping under the fabric, it could be that the top thread is not fully seated in the tension disk. Try this:
Remove the top thread completely from the machine.
Be sure to install a brand new sharp needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Retest your machine.
However, if you don't find a fix, $25 for the special bobbin holder is probably a reasonable cost if it takes care of the problem. The reviews seem to be good:
http://www.sewvacdirect.com/janome-bobbin-case-for-free-motion-quilting-fits-models-mc14000-mc6500p-mc6600p-mc11000-mc7700-mc12000-and-more/
https://thequiltshow.com/forum/domestic-sewing-machines/120-janome-mc6600p
"Yesterday I bought a new free motion quilting foot and a bobbinholder (for free motion) for my MC Janome 6600P. I have been quilting all day, and belive you me it is a greate investment!!! :lol: :lol: Its like sewing on butter :lol: :shock:
Free motion Quilting Foot: part no.: 200-442-004 (MC6600P and MC11000)
Bobbin Holder (for free quilting and hand-look quiltstitch): part no.: 200-445-007 (MC 6600P, MC11000 and MC6500)
Bet you would love to have those too if you are doing a lot of free motion! The quiltfoot you can adjust so it works perfectly on your quilt!
:lol: :D :wink: I am sooooo happy!!!!"
https://www.getasquiltingstudio.com/2012/01/free-motion-quilting-tips-ii.html
LOOPS Tension or Speed
Free Motion Quilting Tension Problems
Mar 01, 2018 | Janome Sewing Machines
How do I free motion on my excel 18w
Free motion is similar on most machines.
Install a brand new sharp needle (embroidery, top stitch, microtex, or universal) of the size that is compatible with the thread weight and fabric.
Drop the feed dogs. If you machine doesn't have the capability, there should be a feed dog cover in your accessory kit that needs to be covered,. This prevents the feed dogs from interfering with your manual maneuvering of the fabric.
Install a darning foot or free motion foot.
Test your stitch and adjust the tension so the threads meet in the middle of the fabric.
Then, it is a matter of practice, practice, practice...
Learn How to Free Motion Quilt Stippling
Free Motion Quilting Tutorial for Beginners Suzy Quilts
https://wpt.org/SewingWithNancy/Video/free-motion-quilting-beginners-part-1
How to Free Motion Quilt on Regular Sewing Machine
lots more web sites available...
Jan 03, 2018 | Sewing Machines
Tension issues on my singer quantum 9960
A #16 needle seems pretty big for FMQ. Are you also getting pin holes in the fabric? Try using a top stitch, embroidery, or metallix needle.
Eyelashing is often a result of moving the fabric too quickly. Try speeding up your sewing speed or slow down the fabric movement. The object is to get the stitch speed equal to the fabric movement--and keeping it consistent. I tend to make swirls too fast which causes eyelashing.
It could also be tension. Be sure to ALWAYS RAISE the presser foot when threading the top thread.
What causes thread eyelashes when sewing
Dec 10, 2017 | Sewing Machines
How to Free motion quilting on Janome 1600P QC
Be sure to use a darning foot (or free motion quilting foot).
Use a brand new sharp needle, ie top stitch, embroidery, or microtex work well.
Check that the thread, needle, and fabric are compatible--Caution, the needle eye should be the right size for the thread weight.
AVOID old or bargain bin thread!
Be sure to drop or cover the feed dogs.
If your machine has it, use the needle down feature.
You may need to adjust the tension for FMQ--I have to tighten the bobbin tension a little to keep the bobbin thread below the quilt surface (so I bought a special bobbin case and set the tension for FMQ and that's all I use it for.)
Lots of web sites that talk about how to free motion quilt. Then, it's PRACTICE, PRACTICE, PRACTICE! I use a portable white board and draw free motion designs on it (while watching TV, etc.). The idea is to get it fluid without jerking, jumping, speeding up or slowing down, etc. When your hand and brain are able to work smoothly, then you can probably do free motion quilting. Practice on scraps of fabric and batting (preferably the same kind you will be working on). Cut up some 14 inch squares of fabric and batting and draw designs on them and see if you can stitch them. Some advice: don't watch the needle...look at where you are going in front of the needle. Don't expect perfection to happen overnight. Many quilters have been FMQing for years and still make mistakes. (I've made a few quilts and my stuff still looks less than professional, but it's all mine!)
Free Motion Quilting with Janome 1600P sewing discussion topic...
All About Needles
Jul 23, 2017 | Janome Sewing Machines
Janome 1600P DBX
You need to drop the feed dogs, install a darning or free motion quilting foot (make sure the presser foot is lowered). Because you will not be using the machine to move the fabric, the stitch length selection is of no importance. Make sure the stitch width is set to zero. You should test FMQ on a scrap quilt sandwich of the same makeup of your project, ie quilt fabric with batting sandwiched between. The upper tension should be set so that both threads meet in the middle of the quilt sandwich. Because it is FMQ, some extra adjustment may be needed.
Once the tension is where you want it, you can practice FMQ until you can move it smoothly in conjunction with the machine speed.
Practicing on a white board with erasable markers is a handy way to learn to move smoothly. The most difficult part of free motion quilting is learning to move the fabric smoothly. Do NOT lack for practice as that is the only way to improve. Those people who make it look simple have been doing it for years!
Free Motion Quilting for Beginners Part 1 Video from Sewing with Nancy
Oct 31, 2016 | Janome Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
Feb 25, 2016 | Sewing Machines
Brother Sq9185 sewing machine, the thread on bottom just pulls out, when free motion quilting? how do I fix this
Sounds like the upper tension needs to be tightened, or the bobbin thread needs to be loosened. At any rate, the tension is correct when the two threads meet in the middle of the fabric for general sewing.
For free motion quilting, the tension should be adjusted so that the bobbin thread does not show on the top of the fabric, however, it should not lay in a straight line like it sounds like it may appear currently. What you are currently producing is a gathering stitch where the bobbin thread can be easily pulled.
Nov 16, 2015 | Generic Brother 130-Stitch Sewing and...
How to attach free motion foot
Most free motion feet attach like the other feet.
It is creating "thread nesting" also called birdnesting. Could be several things:
1) make sure before you thread the upper thread, RAISE the presser foot so the thread will seat properly in the tension disks
2) drop your feed dogs before you begin to free motion
3) your free motion quilt foot, when lowered, should not rest on the fabric. (Be sure you are lowering your presser foot when you want to stitch!) You should be able to move the quilt sandwich easily under the presser foot. If the foot applies any pressure to the fabric, you may need to release the presser foot pressure (consult your manual). Or you are using the incorrect presser foot for your machine.
4) If none of the above, you need to tighten the upper tension AND
try this method before beginning to free motion stitch:
How and Why to Bring up the Bobbin Thread
Aug 09, 2015 | Sewing Machines
Tension and free motion quilting
You don't tell us what happens when you try to FMQ. I'm assuming you get thread loops/mess under the fabric.
Be sure to install a brand new needle that is recommended for FMQ, ie top stitch, embroidery, microtex
Remove the top thread from the machine.
Set the top tension to the midway point and retest your machine on a fabric sandwich just like your project.
Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
This is the manual that comes up for your machine. Probably pretty similar to yours:
Singer 7466 Instruction Manual
If you are getting what is called "eyelashes," you need to match your sewing speed to the speed you move the fabric. Most often the machine needs to stitch faster to prevent eyelashing. Make sure your circles are moved at the same speed--do not speed up moving the fabric in a curve. AND-- Practice, practice, practice on scrap sandwiches, It's an acquired skill, like cursive writing. Only doing it will make you better. I like to practice on a small whiteboard when I'm watching TV. If I find a design I like, I take a photo of it before I erase the whiteboard.
https://www.quiltingboard.com/main-f1/beginning-fmq-beginner-t189467.html
Mar 03, 2018 | Singer 7426 Mechanical Sewing Machine
Tension and missed stitches
It sounds like one of your clearances in the machine is off. When a machine skips stitches like yours is doing, it does so because the hook responsible for "catching" the thread from the needle is not close enough to the needle so it misses the loop of thread from the needle. If your machine was having a timing problem it wouldn't sew well on any fabric. A clearance problem shows up on certain fabrics at certain times. A few things you could do to try to compensate it would be to use a slightly larger needle and turn your top tension dial down to a lower setting. Move the machine a little slower on the frame or increase the speed of the machine. Either way a trip to your technician will be needed. Make sure you tell him to check the needle to hook clearance.
Sep 19, 2009 | Husqvarna Freesia 425
Sewing Machines Logo
46 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
