Question about Kenmore Microwave Ovens
You can barely hear the beep from my Kenmore microwave. How can I make it louder?
Kenmore microwave still beeps when unplugged
There is no battery in a microwave. I can't see how it could still beep for more than a few seconds. Check the kitchen for for another source of the beep. Like a smoke alarm with a weak battery.
Feb 27, 2015 | Kenmore Microwave Ovens
Tip
Error Code "d" - Microwave does not heat
The microwave could be in "Demo Mode" - Check your owners manual.
In Whirlpool/Kenmore models this is indicated by a lower case "d" on the right side of the display panel.
Most/All function except the magnatron (heat) work in demo mode so you can can learn to use the oven without actually cooking food
To clear "demo mode" press the "kitchen timer" pad and hold for 5 seconds until the "d" clears from the display... you may hear 2 beeps.
on Jun 16, 2009 | Kenmore 60654 Microwave Oven
KOT-170SW volume of beeper dropped, can barely hear now. Any assistance appreciated. Norm NC3F normcherry@embarqmail.com
If the microwave is used rather often,the circuit board for the beeper does have a tendency to overheat ,what was once a "high pitched beep"is now a "low pitched beep".nothing can really be done to correct this.If the microwave is still covered by factory warranty,contact the factory.
Feb 12, 2011 | Maytag Appliances Over-the-Range Microwave...
Kenmore model number 721.80593400 everything works but will not heat food it also sounds louder. I just replaced the magnetron and that did not help any ideas.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | Kenmore 80012 Microwave Oven
Kenmore 63252 / 63259 makes buzzing noise during use from control panel side of microwave
transformer probably has a loose fin or 2, it should still work fine but will get louder, I don't think its worth buying a transformer for that mw
Feb 06, 2010 | Kenmore 63252 Microwave Oven
Won't heat up
Code "d" means the microwave is in "Demo Mode".
Push and hold the "Kitchen Timer" pad for 5 seconds until you hear two beeps.
If you check carefully, You may also find this info in your user Manual under "Demo/Learning" feature
ptishkevich
Mar 02, 2009 | Kenmore 60654 Microwave Oven
Kenmore microwave 721 Displays 66:66 and beeps
Try first unplugging power cable for ten minutes, and see if it clears the error.
Oct 24, 2008 | Kenmore 63672 Convection/Microwave Oven
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Ticking sound when running microwave
It may be a noise coming from the turntable motor or stirrer motor, if so equipped.
If it's not too loud, I wouldn't worry about it unless it gets louder or you get further symptoms.
Nov 19, 2007 | Kenmore 62622 Microwave Oven
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave Ovens Logo
75 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
