SOURCE: GE DECT 6.0 GHZ cordless fone (model 28111) don't ring
There is a Do Not Disturb button on the base unit. Press it to turn the feature on and off.
SOURCE: Lost manual for the GE DECT 6.0 Cordless Digital Phone # 28115FE1
http://www.home-electronics.net/ge/pc/IB/28115FE1_IB.pdf
GE phones are distributed by Thomson Electronics...the manuals are available at:
www.hom-electronics.net
SOURCE: My Phone will not connect to the base unit...
My handset displays CONNECTING...
Move the handset closer to the telephone base. You might have moved out of range.
This is what was listed in the Vtech Manual.
What I suggest is not just powering it off, but remove battery and wait a couple of minutes. Put battery back in and try it. The other thing I suggest is a new battery or switching it temporarily with a phone that works, to see if that helps before you buy a new one. If the battery is weak it will have trouble reaching the base.
SOURCE: I LOST MY INSTRUCTION BOOK FOR VTECH 6.O DECT
Vtech DECT 6.0 Dual Handset Cordless 6041 Phone If you click on the above it will take you through to the manual, hope i`ve helped
SOURCE: my cordless phone says
With the phone in standby, press MENU/SELECT on the base.
Move the cursor to select the Register Handset menu, and then press MENU/SELECT. Handset Registering will appear.
On the handset, press and hold # until the handset beeps and displays Handset Registering.
When the handset has registered to the base, the LCD will display Registration Complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
Note: If a handset has ever been registered to a base, reset the handset before you register it to a new base
