The rest of the screen is black, except for the distorted bar in the middle.
You should get the vertical IC checked starting with checking the supply voltage on it. This is a small flat IC attached to a heat sink with about 9-11 pins. This tv model should carry an LA7837 or an equivalent IC. If supply is present, check with means of a magnifying glass for dry solder joints on it. Resolder the pins on this IC if necessary and should work out fine. Model tends to suffer from this problem.
