Question about Panasonic Lands Phones
No incoming call
Panasonic pbx kxtes824
2 Suggested Answers
6ya staff
SOURCE:
Dooper
  • 90 Answers
SOURCE: I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP
only 1 handset rings because in default only one extension is allocated as the operator -
you will nedd to enter system programming PROG * # 1234 AND SCROLL THROUGH PROGRAMMING
you will have to find -
group (enter the member you want to ring)
then aim DDI number at this group
or if analogue line then DIL to point to this group
Posted on Nov 13, 2010
How to i turn on Caller ID on my panasonic kx-dt321 phone ? When an incoming caller rings it just says Line 1 . No number is displayed.The 3 other similar phones all have caller ID when someone rings
If I understood users manual which I found via internet,it is digital system for PBX,so it means you can use it 100% if it is programed thru PBX system,so you need to call your IT personel to program it
for you.
Aug 30, 2017 | Panasonic Lands Phones
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
Answering machine message
The KX-T7730 isn't an answering machine. You need to refer to the documentation for whatever answering/voicemail system you have it connected to. Alternatively, repost your question specifying the make and model of the answering/voicemail system.
Jul 30, 2012 | Panasonic KX-T7730 Corded Phone
We have a new KXTES824 which we are setting up here with a mix of KXT7730 and SLT phones. We've done this before without incident but have an odd problem. We have a single phone connected (PT) and...
One of the ports is shorted or you have the DISA turned on. Start by dialing each extension 101-1xx on the 824 and make sure that none of them are tripping the ring. You'll probably find that one of the ports is bad, the wiring is bad, or there is a programming issue. IIRC the U.K. system is not delivered with DISA, but you may have installed or turned on that feature.
Carl
Feb 03, 2011 | Panasonic Lands Phones
Will the KXT7630 work on the KXTES824 system?
No,the KX-T7630 is a digital 2 wire telephone and the KXTES824 is a analog 4 wire system.
Jan 27, 2010 | Panasonic KX-T7630 Corded Phone
Minutes of use Report for TDA100 Hybrid IP-PBX KX-TDA100
Get yourself a spare PC with a serial port and go here www.mft.com/phonelogger Ignore all the warnings about XP, just run it in W2000 emulation. It comes with instructions.
Carl
May 19, 2009 | Panasonic KX-T7633 Corded Phone
I HAVE A PANASONIC PHONE SYSTEM TDA 100 HYBRID IP -PBX PHONE SYSTEM WITH PANASONIC PHONES KX-T7633 PHONES.WE HAVE NINE PHONES IN THE OFFICE AND I CAN ONLY GET 1 TO RING ON INCOMMING CALL HOW DO I GET ALL...
In program no (620) enter all the extension nos which you want to ring in group 1. Then in program no (450) enter the floating no of group 1. You will get the floating no in program no (623).
Mar 23, 2009 | Panasonic KX-T7633 Corded Phone
Setting the time on the panasonic KX-T7630
This is a PBX system, correct? If so, the fastest way would be through the PBX control computer. If you have a Panasonic TAW series PBX, I really like the AbleComm websites, search for your model PBX there.
Dec 06, 2007 | Panasonic KX-T7630 Corded Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
