My washing machine is giving me an error that says F11 and i was wondering what this code is and how do i fix it?
This code indicates a serial communication error, meaning communication between the central control unit (ccu) and the motor control unit (mcu) cannot be sent correctly. Check the wiring harness connections at the CCU and the MCU. Unplug and reseat and make sure there is no corrosion. It can also indicate a problem with the door lock relay on the control board. I think that I'd recommend getting an appliance tech to take a look at it. Hope this helped and best wishes.
Pull off the front bottom panel and check your service sheet to verify error codes. You probably have a bad door switch.
