Lands Phones Logo
Posted on Aug 19, 2009
I cannot answer to a call with my headset bluetooth
My watch phone P888
the bluetooth function is on
the headset bluetooth is also on (light blue flashes)
when someone calls me i can not answer/ HEAR THROUGH headset
i try to configurate my bluetooth;
my device: empty (no list)
active device: empty
about bluetooth: MTKBTDEVICE BD addr:7c:bb:38:ff:66:01
supported service: Handfree profile, Headset profile, OPP profile, FTP profile
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Aug 28, 2009
Anonymous
Contributor
Level 1:
Answers
38
Questions
0
Helped
5928
Points
56
Just reset the bluetooth
1helpful
2answers
How do I acitivate it
Charge your headset
Charge the headset's battery fully before using the headset for the first time.
1 Put the headset in the supplied charging case and close the cover.
2 Plug the travel adapter into the case's charging socket.
Put your headset in pairing mode
1 Ensure that the headset is off (see Turn headset on/off below).
2 Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
Turn on Bluetooth on your phone and pair with headset
1 Set your Bluetooth phone to discover the headset by following your phone's guide.
Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200
headset.
2 Select Samsung WEP200.
3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK.
4 Enter the headset passkey or PIN, 0000.
Your phone and headset are now paired and ready to make and receive calls.
1 Place the headset over your ear.
2 On your phone, make a call to the number you want.
3 If your phone and headset are successfully paired, you will hear ringing on the headset
After you have successfully paired your phone and headset, you do not need to repeat these initial setup steps each time you use the headset.
To turn the headset on
Press and hold the Multi-Function button for4 seconds until you see 4 blue flashes on the indicator light, then release.You will hear a tone and see the indicator light flashes while the power is on.
To turn the headset off
Press and hold the Multi-Function button for 4 seconds until you see 2 blue flashes on the
indicator light, then release.You will hear series of 2 tones and see the indicator light stops flashing.
http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2
How to pair phone to samsung bluetooth headset wep301? I do not have my user guide.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
Earbud will not connect to lg env2
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
  1. Ensure that the headset is off (see Turning the headset on/off).
  2. Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
  3. Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a 'Setup', 'Connect', or 'Bluetooth' menu on your phone and then selecting the option to discover Bluetooth devices.
  5. Your phone will find the Samsung WEP200 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
  6. Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
wep200-5.jpg If pairing was successful, the indicator light will flash in blue 10 times rapidly before going to flashing every 3 seconds. If unsuccessful, the light remains on, and you will need to re-attempt pairing.
How do I setup wep301 headset to a simple at&t phone
Follow the steps to connect your WEP 301 bluetooth headset to phone.
1.When you turn on your Samsung Bluetooth
mode immediately.
blinking.
by following your phone’s guide. Typically, the
steps involve going to a ‘Setting’, ‘Connection’,
or ‘Bluetooth’ menu on your phone and then
pairing.
Thank You
Lost instructions for how to get my cell phone connected to my samsung mep 350 calls for pin and i dont have one
1 Enter Pairing mode.
• Turn off your headset and press and hold the Multifunction
button until the blue indicator light remains lit
after blinking.
• If you turn it on for the first time, it proceeds into Pairing
mode immediately.
2 Search for and pair with your phone according to your
phone’s user guide. (Bluetooth PIN: 0000, 4 zeros)
• If the pairing is successful, the blue indicator light will
flash 10 times rapidly before entering Standby mode.
• If the blue indicator light remains lit, retry pairing.
Pairing with your Bluetooth phone
When the headset and the phone are paired, the
headset attempts to reconnect automatically each
time it turns on. Otherwise, press the Multi-function
button to reconnect.
USER GUIDE
2helpful
2answers
Bluetooth
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select Explorer 220 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
8helpful
2answers
Motorola bluetooth pairing
4.Select H700 once a connection is detected.
Tips:
2helpful
Bluetooth problem
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select (serched bluetooth serched device) once a connection is detected.
Tips:
3helpful
3answers
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
