Question about Jacuzzi Home
Where is the reset button on my jacuzzi - Jacuzzi Home
Need to know where the reset button is on Kohler jacuzzi tub
The only place I'd expect to find a reset button is on the motor itself. That is, unless it's a ground fault problem, in which case it might be on another ground fault outlet somewhere in the house (possibly a bathroom or garage outlet) OR on the breaker - check the breaker box to see if the breaker's tripped or the GFE button needs to be reset.
Aug 02, 2017 | Jacuzzi Home
Jacuzzi Amiga motor does not tuen on. Hardly ever used
There are no reset buttons on bath pumps. It may be the motor is bad or the toggle switch is bad.
US Parts Center
Jan 26, 2014 | Jacuzzi Amiga Whirlpool JAC-N888...
Locate reset button jacuzzi
on the gfi box ther eis a red button and a black one..push the red one first then the black one.. it should start up..if it keeps kicking off look for a reason(leaks wet parts etc)
Oct 23, 2013 | Jacuzzi Pool & Spa
My jacuzzi tub will not come on . fist it was making a humming sound , i turned it off checked the reset plug tried to turn it on and not a sound
mine did the same thing. the tub is plugged into a ground fault interupter (gfi) plug. hit the reset button. if this doesn't work, check the circuit the gfi is on, sometimes they are on the same circuit as the plugs at the sink. check them for reset also. if this fails, on the motor of the tub, there should be a reset button. try to reset it. OH first make sure the breaker has not been tripped.
Jan 04, 2011 | Jacuzzi 4481-959 Nova 5 Soaking Bath 5'-...
Can't reset the inline heater on Jacuzzi/LED broken
You have a newer heater which has a self reseting thermal overload protector just shut the spa down for up to 30mins in some cases all depends on make an modle an the heater will reset itself some are as fast as 30sec.
Jan 26, 2010 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Jets not working in my ten year old jacuzzi bath
Open pannel and look for a reset button on or near the pump motor.. Or it is posible that the pump motor is shot..
Have a great day !
Nov 11, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
My jets wont turn on
All the electric power source to all jacuzzi tubs all required to be protected by a "ground fault" device. Have you noticed special wall receptacles in your kitchen and bathroom that have 'test' and 'reset' buttons? There may be a receptacle (or something that looks like a receptacle but without any slots for plugs) near the tub. Push the reset button. If the pump for the tub has an access panel, the device may be behind the panel. And last, the circuit breaker in the main electrical panel may be a ground fault type and needs reset there. Good Luck
Jul 09, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Do Magnum Force Pumps have a reset switch ?
No jacuzzi magnums do not have a reset button. First make sure breaker to pool is off, then remove rear motor cover, and take a look. Popping noise sounds like an arked wire. Could be a bad terminal or just aloose power wire. JACUZZI PUMPS ARE GOOD QUALITY, AND USSUALLY RUN FOR MANY YEARS. Pump can be removed for repaair, or motor replacemant by a qualified, and republe pool shop, for rebuilding Ussually rebuilding is about half the cost of new. Kirk
Feb 09, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Home Logo
70 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
