Televison & Video Logo
lucas martinez Posted on Jul 04, 2019
Trying to get air tv on an akai 32" LCT3285TA
What channel should the tv be set on? in the tv menu what channel should be set there?
3 Related Answers
jessee007
JP Services
  • 310 Answers
  • Posted on Jan 07, 2008
SOURCE: Akai LCT3285TA 32in cant find 4 digit codes for tv?
all in one
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
A
Anonymous
  • Posted on Aug 01, 2008
SOURCE: AKAI LCT3285TA static noise
Which input connections are you using?
Anonymous
  • Posted on Oct 19, 2010
SOURCE: Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to partsstore.com this is where I found the power supply board for this TV.
2answers
Im having trouble hooking up my desktop computer up to my Akai LCT3285TA tv? what am i doing wrong? I have both VGA hookups connected and screen says not supported?
The screen indicates 'not support' because the resolution you are try to feed the TV exceed the maximum it can display, you need to set your computer video out put resolution the TV native resolution, which you need to find out by download the user manual here: http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
2helpful
We havw a 32
Are u using free over tthe air signal?
Get a better antena like a digital antena or a roof one.
Volume is stuck on 0
Akai TV's are knwon for various issues, this is one of the ones i have had to deal with repairs for many times now, first jsut pwoer reset it, unplug it for 3-5 minutes and try another outlet, try a dvd player as well jsut o insure there is no sound, akai has no tech support as they ahve gone out of bussiness, i suggest calling the local television repair center or returning it
Im trying to program my remote for Cable...
Target sells a GE Universal Remote Control, 5 Device with learning feature. Its code for the Akai LCT3285TA is 1139.
Other remotes may use different codes, or have none that will control this TV.
1helpful
Akai LCT3285TA-need stand-remotes and 1 component input dont work
Check it out, is that remote you need for your Akai TV?
HERE is another remote but I'm not sure.
Progressive scan
Approach 1: Try unplugging the DVD player from the wall for an hour, then plug it back in. It may or may not reset to the factory default settings, which might put it back to "interlaced" output.
Approach 2: When a DVD player is switched to progressive scan, it uses outputs different from the coax cable "TV out" and the COMPOSITE outputs (often yellow, white and red RCA jacks. If you have the proper cables, you can connect them to both the DVD player and the TV, then cycle through the AKAI TV's "source" settings to switch the TV to the new cable input location.
For example, if the DVD player has "component" outputs (marked Y, Pb, and Pr) hook up RCA plug cables between those jacks and the AKAI TV's Y, Pb, and Pr jacks. Connect the Y to Y, the Pb to Pb, and the Pr to Pr, of course. The LCT3285TA has two sets of these jacks. Either will do, but note if you use YPbPr1 or YPbPr2. Once this is done, push the source button on the side of the TV (or on the TV's original remote) until it shows YPbPr1 or (...2 if that's what you connected). If the DVD player is on, you should now see the DVD menu or the picture from the DVD. Now you can use the DVD remote to switch back from progressive to interlaced video. The picture may go blank at this step.
Now push the TV's source button again until you see "3" or whatever channel you had been using in the upper left of the TV screen. You should see the DVD output picture (menu) again. Back to normal.
If your DVD player doesn't have YPbPr connections, it may have a HDMI or DVI jack.
The AKAI TV also has a HDMI input, you *could* get and HDMI cable (or DVI to HDMI cable if the DVD player doesn't have HDMI), hook it up, then cycle through the TV's source inputs until you see the HDMI in the upper left... in the manner I've just described.
Final Note: The progressive scan output of your DVD will actually give you a much better picture on your AKAI TV than its interlaced output. To take advantage of that, you'll have to hook up YPbPr or HDMI cables between player and TV and switch sources when you want to watch DVDs instead of TV programs. You may need additional cables to send the stereo audio output from the player to the TV for the progressive source hookup.
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
