Microwave Ovens Logo
V
Vincent Short Posted on Jul 03, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Kenmore Microwave Hood combination that will not heat. Turn Table works and fan comes on but does not heat. Did I press a wrong button? How do I get the microwave working again?
Vernon Taylor
Level 3:
  • Kenmore Master 7,446 Answers
  • Posted on Jul 04, 2019
 Vernon Taylor
Kenmore Master
Level 3:
Answers
7446
Questions
0
Helped
1959606
Points
26207
I suppose it is possible you pressed the wrong button - if you disconnect it from the power for a few minutes it should cancel whatever action you might have taken, though realistically it is more likely your microwave has developed a fault that is best tackled by the repair shop.
5 Related Answers
Anonymous
  • Posted on Oct 24, 2009
SOURCE: kenmore microwave doesn't heat up
I have the same microwave kenmore 721.62624200. I bought it 5 years ago and the same thing happened. It started humming and it's not heating. All of a sudden this just started happening. Is it worth fixing it?
Anonymous
  • Posted on Nov 09, 2009
SOURCE: Kenmore Microwave Hood Combination oven Model Service code (SE) ?
I have Microwave Kenmore model 401.80082700 about more than a year. After about 6 months, it stated to have some probles such as some number keys not working. Then button START become nor working some times. I can use only button of 30 secon increment to cook something. OK, the fan is working for most of the time but the levels are stuck, not adjustable. I can't changer the fan levels. Now the lamp buton is dead. Sometime, the fan level control is working by itself level 1, 2, 3.... then it appears -SE- on the display. nothing work now. I unplug.... then plug back, it ask to input the time or date... I can't do any thing. Later some time I can cook by using 30 secon button.... It is anoying. Please how I can fix it? Thank you.
Anonymous
  • Posted on Nov 29, 2009
SOURCE: Our microwave suddenly stopped heating. The
sounds like the magnatron went out
Stephen Lam
  • 670 Answers
  • Posted on Dec 24, 2009
SOURCE: Bosch Microwave HMT8625 range - Microwave not working
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
Anonymous
  • 43501 Answers
  • Posted on Aug 23, 2010
SOURCE: My Kenmore Microwave Hood Combination Model
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
1helpful
I got a Kenmore microwave hood combination model number 721.80032 is it a hood fan to and how do i just turn on the hood fan
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
The manual for the 721.80032700 is available here: https://www.searspartsdirect.com/partsdirect/user-manuals/72180032700-kenmore-parts-manual?manualIndex=0 . The direct link to the Owner's Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0710653.pdf . See pages 9 and 14 for using the exhaust fan.
I hope this helps.
How do I fix the key pad of a Kenmore microwave model 401.80084700?
I don't know of anyway to repair the keypad. Usually replacement (of the keypad/control console) is the only option. But you might want to remove the ribbon cable that connects the keypad to the control board behind it, clean it with a degreaser (like Fantastic or 409), dry it, and re-insert it, and then try again. (Remember to unplug the microwave oven first before you try that!)
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
4helpful
Kenmore Microwave Hood Combination 721.80019 does not heat. I follow all the troubleshooting procedures. Nothing solved the problem. Help!
My kenmore microwave will not work. The light stays on inside, buttons will push, but the start button does nothing. I've tried everything. The last thing I did was express defrost which was fine. Could it be something really simple? I hope so.
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
2answers
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
