SOURCE: I have Heath/Zenith wireless doorbell.
"sometimes out the blue it will chime"
if for example the doorbell runs on 2.4Ghz signal and then you have a wireless phone which is also on the same frequency, everytime you use the phone the doorbell will ring. got it?
SOURCE: my pushbutton doorbell activates my neighbor's chime
in the chime box and remote you can change the setting for the remote signal that is picked up( refer to your manual for the correct settings) these will be a set of pin connections in the chime box and in the remote switch that will have to be set to another selection
SOURCE: I'm working on a remodel.
Sorry thats not possible. What you will have to do is get another LE75 and put it in the 2nd location
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Is the transformer the same for both units. Check the voltage and make sure its the right voltage. There should be a transformer where the electrical wires come out and hook into the main line to your unit.
Mine is hooked at my main electrical box. Not all units have the same voltage.
