I presume you have a TDA system with TVA voicemail?
FROM YOUR OWN EXTENSION, On the intercom dial 500 (or 165) The voicemail should answer. If it asks for a password and you do not have it, the Administrator will have to reset the mailbox. If it only gives the front end greeting then no mailbox wsa assigned.
SOURCE: My red message indicator light
Press the MESSAGE button and look at the display. The red message light is lit from any phone pressing the MESSAGE button when they call you or (a Pana whoops) dialing 4 into the busy tone.
One of the soft keys under the display will be CLEAR. That clears the message from that phone.
Carl
Testimonial: "Thank you!!! That solved everything!!"
SOURCE: How do I program my panasonic KX-DT343 handset to
You do that by programming the ICD groups on the phone system it's attached to.
It requires system programming access and probably a knowledge of ICD group 601.
Carl
SOURCE: need to change hold music
It depends on where the music source is coming from. A Panasonic TDx system has a port for external music located on the system cabinet. If it's enabled in programming, that's what you hear. If not, you get an internal "tune".
If the music is exterhal, all you have to do is find the box that is playing the music and change the recordings. That's a whole other topic :-)
Carl
SOURCE: how do i change the
From the phone connected to extension 101, press PROG and dial **1234 If the display responds Sys Prog #, then dial 004 and enter. It's the menu to assign names to extensions. You can sort of follow along and use the arrows, the keypad, and the ENTER and SAVE buttons to step through the names and change them.
Carl
SOURCE: How can I make the
The PT display clock is systemwide and done by your Panasonic installer or someone with access to the Maintenance Console. It's option 2.9.1 and the format is either 12 or 24 hour as one of the checked options.
Carl
Please note, I am the messenger. I can't change your system and you can't program it without the console software.
