Removed all paper jam and comes up with "print unable 50" see troubleshooting and routine maintenance.
Solution #1 is absolutely spot-on from adnanbhatti, copy the link into your browser to be able to see the photos of the printer and how to slide the print head:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000065/faq000565_013.html?reg=us&c=us&lang=en&prod=dcp130c_all&Cat=11
When I slid the print head over as specified, I found a little crumpled paper fragment soaked with ink. Pulled it out.... I turned on the printer, it ran a cleaning cycle automatically, and started printing just fine!
I quote this from the official Brother website.
Address:
Title:
"Howdo I clear the message Unable to..." ( "Unable to Change" "Unable toClean" "Unable to Init" "Unable to Print" "Unable to Scan" )?
Description: Themessage "Unable to -" ( "Unable to Change" "Unable to Clean" "Unable toInit" "Unable to Print" "Unable to Scan" ) is a general message and mayappear for different reasons.
To clear the message, you need to disconnect the Brother machine from the power outlet to check the machine.
Follow the steps listed below:
NOTE : The images shown below are from the representative product and may differ from your Brother machine.
Disconnectthe machine from the power outlet and open the scanner cover by pullingup on the lower right corner of the cover. Look inside the machine andremove any foreign objects. If you see jammed paper or another iteminside this area, gently pull it out and then close the scanner coversecurely.
2-1.Disconnect the Brother machine from the poweroutlet.
2-2.Open the scanner cover by pulling up on the lower right corner of the cover.
2-3.Check the print head's position.
In the example photo the print head is positioned at the left hand side of the platen area.
2-4.Gently move the print head to thbrother 130c print unable 50 - jam6.gif.
Caution
Be careful to not force the print head to move.
If the print head is positioned at the far right hand side, youcannot move it. Please contact Brother Customer Service.
2-5.Examine under the prinbrother 130c print unable 50 - jam7.gifIf anything is found, remove it.
Hint
Use a flashlight if necessary to check thoroughly.
2-6.Close the cover and reconnect the machine to the power outlet.
If the message continues to appear on the LCD, the machine will require repair.
HP was one of the first companies to introduce laser printers among the users. HP is known for its steadiness, user-friendliness and consistency. In case, you are facing any problem while using HP printers, call on our HP printer toll-free number for quick assistance. Visit: https://hp-printer-help.com/hp-printer-support/
Solutions to Fix Brother Printer Error Code 76:-
Solution 1:- Change the Fuser
The Error Code 76 in your Brother printers is also related to fuser error, so you need to change the fuser, but first just in case try to reset settings to factory defaults.
Solution 2:- Change or Update the IP Address
The other solution is that is to change the IP Address. For this you have need to do right click on your printer, click "Properties", then click the "Ports tab" then hit on your Brother printer and then click on "Configure port: (or you can delete the existing one and then add another one).
Furthermore, if you want to do is update the IP Address, you can. But the problem is that the Brother Printer doesn't have a static IP address, it's dynamic. If you want to confirm that, then go to your Brother Printer and press the "Reports" button and then print out the network configuration report. Now your IP address will show on that. It's actually the last digit in the IP address that changes. This will absolutely solve your problem.
For more Info Visit Us: Fix Brother Printer Error Code 76
