600 low voltage transformer hook up to 3 outside pedestal lights
Only one light came up the otther 2 don;t work, they only work for 2 weeks and now only one light work. could it be the transformer went bad.
thank you carlos
ML 600 will have 2 sets of ABC terminals. Each terminal supports 300 watts. Split lights between both sets of terminals. Use 12 gauge wire. Maximum 75' length each wire.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on timer or any do-it-yourself project. Fixya is always less expensive than a service call.
Upvote the help.
And take advantage of fixya expert assistance live.
Upvote the help.
This is more than likely what has happened . I am going to guess that your original low voltage trasformer was a 120 volt .6KW. Or 600watt transformer that has one lead from it to the lights . The newer less expensive transformer is also 600 watts , but the new one may have 2 sets of wire terminals on the back( 4 screws ). If this is the case , you have a transformer that is 600 watts output but it has 2 seperate 300 watt outputs that won't run 600 watts from 1 set of output screws . You will have to seperate the lighting load and may have to run an additional low voltage wire to half of your lights . In other words . Put 300 watts of light on 1 set of 12volt output screws and 300 watts on the other se of output screws .that will solve your issue . Good luck and enjoy your lights again . John
