I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
I have a jenn-air sealed gas cooktop jcg8430. The back right burner sparks and ignites, the other 3 spark at the back right burner when the individual knobs are turned on, the 3 will light with match
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Most likely the electrode for the right burner is defective. As well as the switch may also be defective (is shorted because of pressing hard on it trying to make it work!!). Change the electrode and igniter switch of the right front burner.
It seems like you got water into the ignitor switches on under the knobs. Sometimes it takes 48 hours for this to dry out. Or you can pull the knobs and use a hair dryer on to dry out the switches. Also you can try to clean it. Please refer to the link and picture:
Please do accept the solution and revert for further assistance.
Thanks
Rylee
Did you spill water near/on knobs? if so leave to dry out for 24 hours. If still clicking after 24 hours one of the switches has shorted out and needs to be replaced. You can find which one with a multi meter/condinuity test.
Hope this helps...Good Luck
it may just need cleaning at where it sparks to the burner if it is sparking back down the electrode then it is cracked . Some igniters pull out others have a screw that holds them in.
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
