Samsung LN40A450 LCD TV Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my samsung lcd tv model le40s8, it won't switch on when i press the power button on the remote the red light starts to flash and it makes a clicking noise and won't turn on
Anonymous
Level 2:
  • Expert 36 Answers
  • Posted on Nov 12, 2009
Anonymous
Expert
Level 2:
Answers
36
Questions
0
Helped
29399
Points
162
If you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Aug 17, 2009
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2821065
Points
26282
Ur power board inverter is dead.
U need a new board.
jhun T
Level 2:
Sergeant:
Champion:
  • Expert 341 Answers
jhun T
Expert
Level 2:
Sergeant:
Champion:
Answers
341
Questions
Helped
108024
Points
954
Common problem is the power supply circuitry. have it checked
Sky remote code for model UE40J5100AK
Programming the remote control
To control your TV firstly switch on the TV set, point the Sky remote at the TV, press the "TV" button on the Sky remote, then press and hold the "Select" and "Red" buttons together until the red light at the top of the Sky remote control flashes twice. Press "TV" again then enter the code for the TV listings below (Use the 4 digit codes from the left hand column), the red light will flash twice if a valid code has been entered. Press TV then the standby button on the Sky remote control, this should switch the TV set off, if so then press the "Select" button to store the settings. You should now be able to switch the TV back on and use the volume control button from your Sky remote.
If the TV did not switch off then it may require a different code, you can either start again using one of the alternative Direct codes below or continue with this process by continuously pressing "TV" then "Standby" then "TV" then "Standby" etc until the TV set switches off. This will provide a manual scan for variations within that product code.
If you are still unable to control your TV from the remote control see: Programming The Sky Remote or go to Sky's official website where you can see if a particular remote control version number will operate your make of TV, this can be found at:Skyplease remember to use your back button and come back to us.
www.electro-medical.blogspot.com
Samsung brand code 0060
3 digit code for Samsung
065, 584, 037, 245, 476, 398, 516, 292, 318,037
1helpful
4answers
Samsung 40" lcd ln40c530f1fxza won't turn on
The main board would be susoect next if the power supply has already been replaced.
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • 0helpful
    Need an activation code for my sky+ remote to operate the volume on my samsung lcd tv le40s8.
    switch to sky on tv and press interactive on sky remote then move down to sky customer service (select) once screen has loaded move down to programe your remote you will need model number and make of tv press select and then enter the make of tv by moving down list once found select and repeat for model then follow on screen instructions
    32helpful
    2answers
    I want to find the Sky remote code for this Tv.
    Just got an LG 42LH2000 and code 0206 works
    1helpful
    Sky remote code fo LCD LE40A456 TV
    1. Press tv on your Sky remote control.
    2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
    3. Press tv again
    Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
    Samsung Code: 0060
    4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
    5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
    1helpful
    2answers
    Configuring Sky remote
    3. Press tv again
    Samsung Code: 0060
    6helpful
    2answers
    Sky remote tune to samsung
    3. Press tv again
    Samsung Code: 0060
    2answers
    My samsung tv wont turn on, red light keeps flashing on the front.
    i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
