Spa model 2000M7 from Balboa Instruments with a "Balboa" control panel. There is power to the interior of the spa. the fuses are good. with the power turned on there is no illumination at all on the control panel. Is there a "reset" switch of some kind that i'm missing here???? thanks for helping
There are at least two separate circuit breakers feeding your spa and two reset buttons. the circuit breakers are located a few feet away from the spa in an electrical box.
the reset buttons are in the mechanical space of the spa where the pump and heater are located.
here is the service manual in case you dont have one. http://www.emeraldspa.com/information_an...
look on pg 14. it appears that your circuit board may need to be replaced. Regarding the reset buttons, I misspoke, your spa has two internal suses instead. once again i refer you to the link above.
Did u ever figure out what was wrong??
Thx for your reply. As I said, there is already power to the interior box of the spa. So it is not a GFCI reset issue.
Could you be more specific about the location of the "reset" buttons you mentioned on the circut board area of my spa model.(Balboa 2000M7) I have already had the panel off inside the spa and exposed the cicut board, but I can't locate the "reset" buttons you're mentioning. Please be more specific. thx
