SOURCE: Murray riding lawn mower
I have a 12 HP Murray riding mower about 6yrs old model 30577X8A. I am having trouble shifting it in and out of gears, ever thing runs just fine can you help?
SOURCE: Older model Ariens ride around lawn mower - drive belt slips off
it could be the belt has streched
check tensioner if has one and check all nuts and bolts tight
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
SOURCE: I have an Ariens riding
English Owners Manual
http://apache.ariens.com/manuals/027497F.pdf
English Parts Manual
http://apache.ariens.com/manuals/027551C.pdf
English Service Manual
http://apache.ariens.com/manuals/RM927-1983.pdf
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Testimonial: "These were the manuals I was seeking. One question. The Repair Manual on the first page goes through model 927027. I have a model 927037. Is it Ok?"
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
