I have used my HP 3210 without problems for about a year. One day I used it and next time I looked, it was turned off. That has been over a week, and it WILL NOT turn on. I have repeatedly checked all the connections. To make matters worse, I can't find my install CD. Help!
I am experiencing the same. Unit will not turn on. The only sign of life is that when pluggeg in or unplugged the front panel displays flash briefly and dimly (less than a quarter second).
You can't post conmments that contain an email address.
The error that your having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Occasionally printer cartirdges can clog and become unusable after refilling them several times. Also, if a printer cartridge has been "dry" for a long period it may experience the same problem. Your best bet is to buy replacement cartridges for any colours that show problems on the test page. If there is a blue & green hue to your printing that would suggest that the magenta is not printing and should be replaced.
i had thed same problem. after hours of trying different options i finally got it to work. i have a hp 3210 that i brought from the usa to irelnad and when i put in irish cartrtidges it said " this printer is cinfigured to use 02 cartridges" Iriss cartridges are 363. so what i done was , while the printer was turned on i held down the " Black" button and the "Color" button at the same time. Keeping them held I powered off the printer , keeping them held until the printer was completely powered off. when i turned the printer back on the region had being reset and it asked me to choose my language and country. chose " Ireland". Now works!!!
It is possible. You will have to go into the properties of the printer you're using. Assuming you're using WinXP, go to Start>Printers and Faxes and right click your color printer. Choose Printing Preferences. Using my HP Photosmart C3100 as an example, I would next choose the Color tab and under Color Options, choose the radio button that says Print In Grayscale. That will do it.
ok u neeed to to remove all old drivers all printer driver form add remove then run www.ccleaner.com tool get left junk out then go to hp.com download latest driver for your printer vista or xp need try that 1st thx nick
I tried the Cleaning Kit HP sent me. At the time they didn't mention that it required a direct USB hookup rather than the Network setup I was using.
Another user suggested using Lighter Fluid sprayed on the defective (too hard) paper feed wheels. Crazy solution? Lighter Fluid is mainly Naptha which the user claims softens rubber.
I tried it last night and waited for the fluid to evaporate before plugging the printer in. I really expected the darned thing to go up in flames so I had a pot of water and a blanket nearby as a fire precaution.
Much to my surprise .. the PSC 3210 has been feeding sheets perfectly for the past two days! This is after sitting in a HOT attic abandoned for over a year! I had to replace one ink cartridge which had dried out completely.
I don't know how long this "fix" will continue working but Lighter Fluid is cheap. The PSC 3210 is a quality printer WHEN it prints. It's too bad HP created so much bad will in its customer base because of defective rubber paper feed wheels. I've avoided purchasing HP products for two years now and have warned others to stay away because of this fault with customer service. Instead of replacing the defective rollers in my original printer, they exchanged the printer for a refurbished printer with the same defective rollers!
