I have a crosley conservator electric dryer and i need to switch my original three prong power chord with a four prong power chord but i cant find a wiring diagram to help me do it. do you know where i can find one?
Almost all dryers have three screws to fasten the wires to the dryer like the following;
0 0 0
Red White Red
or wire or
Black Black
red and black are both "hot" wires so either work in either spot. The middle screw is for the neutral "white" wire. The fourth wire on your 4-prong plug, the "ground" is usually green and may not have a screw to fasten to because the dryer came with a three prong plug that doesn't have a ground wire.
Look for a copper strap attached to the frame below the three screws and attach the loose end to the white wire screw "neutral" along with the white wire.
Your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Here
is a tip that will help you with changing your dryer plug.
Dryer
Cord
and Wiring Dryer 3 Wire or 4 Wire
heatman101
