Hi Guys, when I use the front camara my nokia n73, I get the above message. hardware failure restart camera I've tried restoring the original phone settings but it hasn't made any difference. I'd appreciate any suggestions. Many thanks
SMFarhan
Nokia n73 front camera hardware failure
Nokia n73 front camera hardware failure solutin
Pleas tell me how slow a this my problem is nokia n73 frent cam is not working
Yaa. same happened with my mai camera. i restored my phone so it worked for 2 days then iit was again same problem of hardware probllem.. so i went to nokia care and they replaced they camera.. ur camera will be replaced nd if sum times they have a problem with replacing front camera so wht they do is replace they whole phone..
Hardware failure;restart camera n73 nokia
SOURCE: Hi Guys, when I use the front camara my nokia n73,
Since, your cell is giving hadrware failure that means you have to get it serviced. There is a possibkility that either your front cam or IC on motherbioard has been stop functioning,,, SO get it serviced...
But I think that there could be a software corruption. So I advicesed that before getting it serviced, Update your cell software and check that whether there is a actual software or hardware problem.. Visit to the given link, to know software updation process...
http://www.fixya.com/support/r4743802-nokia_software_update_or_applications
Before updating dont forget to back up your phone memory including sms and contacts...
Hope this has helped you....
Please rate the answer...
Thanks....
The phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
try and format to confirm if this helps to resolve the issue. check this link
http://www.blogsdna.com/2278/how-to-format-nokia-n72-n73-n81-n95-nseries-mobile-phones.htm
