Ovens Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stoves 900GTF main oven flame keep flickering and reigniting
I have a Stoves 900GTF and every time the main oven is switched on the gas burns for a while then flickers and goes out then reignites, then flickers then goes out etc. etc. It is as if it is in a draft or being blown out by the fan or something.
Anonymous
Level 3:
  • Master 998 Answers
  • Posted on Aug 17, 2009
Anonymous
Master
Level 3:
Answers
998
Questions
0
Helped
248599
Points
3069
Try adjust air hood
Main oven works but the ignition keeps clicking while oven on
check the operators manual or with a servicing agent
being gas it may require the clicking to reignite the gas when the temp starts to cycle or there may be a problem in the control system for the gas operation
May 04, 2016 • Ovens
Stoves 900GTF oven sparks but won't light
You may have problems with the gas valve, but check the wiresgoing to it first see anything came disconected
4helpful
Reconnecting terminals onto stoves 900GTF double gas oven
\i have a stoves 900 GTF double gas oven. The clock has suddenly started to flash. It does not enable me to set the time and therefore I cannot use the main bottom oven. I am unable to overide the auto to manual. Can anyone help me with instructions or with solving this problem. I have mislaid by instruction booklet. Thanks.
1helpful
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
2answers
Wolf oven - oven clicks continuously
This sounds like you have a flame switch getting ready to go out. The reason you are hearing the ticking noise is that after the ignition is satisfied the flame switch is not detecting and sending a signal to continue to try for ignition.
Nov 02, 2008 • Ovens
4helpful
Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
1helpful
2answers
Gas cooker keeps igniting
Sometimes when I clean my cooker, and it gets damp, mine ignites like that. It soon stops after it dries out. Give it chance and see.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
