power voltage drop of 10 volts where you are
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
if found to be the issue and no slide switch to change on the TV somewhere
you may need a converter to equal 60 hrz
sound ok
any luxor should work there
i am thinking local signal signal
cable or roof antenna in the place
if auto auto tune or manual tune wont give a picture
not sure if a converter is needed
i am thinking try
. if coax cable old
re do all connections or replace with new cable
could get a TV antenna guy to reset the roof direction signal
if no better ..have doubts but
different channel wave lengths or faulty signal receiver
does the user manual cover world wide distribution or support
information
no online luxor TV support contact number
just a wiki information link
a long phone number ???
the internet email address is looping
[email protected] http://luxorhelp.com/luxorhelp/wiki/index.php?title=Tech_Support
