Sharp LC-26D4U 26 in. LCD Television Logo
Posted on Aug 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sharp LC-26d4u tv won't turn on/power light is off
Sharp LC-26d4u tv won't turn on. power light is off. any ideas?
Chi Chu
Level 3:
  • Sharp Master 8,457 Answers
  • Posted on Aug 17, 2009
Chi Chu
Sharp Master
Level 3:
Answers
8457
Questions
0
Helped
2822876
Points
26282
Check ur power source,unplug replug if not work,Ur tv power board ic inverter it dead needed to be change.
Sharp Aquos LC-26D4U sound problem
Yes this is a common problem. You have to have it refered to a TV SHOP. I can fix it for you but in CA. the wiring on the speakers needs to be upgraded to a thicker wire. The gauge is to small for the current needed to flow evenly.
$75.00 Fix
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
1helpful
Go to turn on tv and all I get is flashing red light and tv won't turn on. Was working the other day.what do I check?Sharp LC-26GA5U
Try unplugging the TV from the power point and leave unplugged for 5 min.
Or the batteries in the remote may be flat, try replacing the batteries.
If this doesn't work the TV may have a fault.
I hope this helps
MobileJB
1helpful
2answers
Digital signal for my Sharp Aquos
Hi
On the TV menu did you change it from Cable to ANT?
My sharp aquos television sound is very low even on max.
I had this problem with my Charter and the box had a sound button on the actual box, not the remotes. Now I have switched to Direct TV Box and have found while not so low I can't hear it, it is much lower than I know it can be and have to turn it up in the higher numbers or turn on the surround sound to hear it. Anyone know what to do with Direct Box, Direct didn't know.
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
8helpful
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
